Thread: Rust on gtp!
Results 1 to 17 of 17
  1. #1 Rust on gtp!
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    Hi everyone, I live in iowa and I absolultely love my 99 Grand prix gtp Would not trade it for anything, I am posting this to day because I was washing my gtp after school today and there was water in my trunk. I pulled the carpet back and this is what I saw...
    RUST ON MY SHOCK TOWERS AND IT WAS LEAKEING WATER IN, my rockers are gone as well idk what to do, I wanted to see what you guys thought if i should fix it or get another one.
    I would no doubt get the same body style I love this car with all my heart!!! i would keep it for parts if I were to get a new one with NO RUST!
  2. #2 Re: Rust on gtp!
    Thats not that bad, you can fix that pretty easy if you go the tools.
  3. #3 Re: Rust on gtp!
    Mar 2012
    NC
    Oh no's! Rustages!
    There's mine. My dad is a body guy and built plates to repair the rust. This is after the strut "bucket" had all of its spot welds drilled out. No doubt yours is probably in the same condition. If it weren't for the fact that my dad is awesome, I would've scrapped this car. If you know a body guy willing to work on the cheap, it is fixable, but otherwise you should consider looking for a cleaner car.
    EDIT: This side looked just like your second pic from the top. I notice the strut "bucket" starting to push upwards into the trunk. What you see will flake away if you poke at it too much.
  4. #4 Re: Rust on gtp!
    GTP Level Member
    Oct 2011
    Raleigh, NC
    not that bad for a Northern car.
    1997 Red GTP 182000 miles stock
  5. #5 Re: Rust on gtp!
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    ^^agreed, i got rid of my old 97 se because of this problem. found my gt for 600 couldnt complain so i junked my old one.
    i know of a place in waterloo, ia that will fix that up for about 200, if yur curious.
  6. #6 Re: Rust on gtp!
    Madrid Iowa
    Wow thats way worse than mine, my dad is some what of a body man and my grandpas friend owns a body shop, so i will go and see about that. Glad you saved the car I love grand prixs(: I will pri have the rockers done to while im at it!
  7. #7 Re: Rust on gtp!
    Madrid Iowa
    I would deffenatly like to know about that!!
  8. #8 Re: Rust on gtp!
    Mar 2012
    NC
    Quote Originally Posted by GrandPrixgtp2000 View Post
    Yeah it was pretty bad. Pull up your carpet and check where the floor meets the inner rocker panel. If the rocker panels have holes, this area is prone to them as well.
  9. #9 Re: Rust on gtp!
    Madrid Iowa
    Quote Originally Posted by hitman92499 View Post
    i will do that this weekend when im not in school because if they are bad im going to have them redone to!
  10. #10 Re: Rust on gtp!
    Madrid Iowa
    Quote Originally Posted by GTP in RTP View Post
    good luck
    Thanks bud. I was going to redo the car next summer anyway I just wanted to get some in put and see if i should just get another car or redo this one but now iknow my anwser. Thanks boys!
  11. #11 Re: Rust on gtp!
    May 2012
    Waterloo, IA
    LJ's Welding and Fab. mine were completely shot through (touching my rear speaker deck) and they told me 300 to do it. yurs arnt that bad so i bet itd be cheaper.
  12. #12 Re: Rust on gtp!
    Mar 2012
    NC
    Overall, my dad had both strut areas repaired with about 10 hours of work. The floor section is easy because there's just seam sealer in there with a few spot welds, the rocker panels can be purchased and installed in a matter of hours minus paint.
    EDIT: And the rear strut tower repairs look factory underneath and are stronger then new!
  13. #13 Re: Rust on gtp!
    Madrid Iowa
    Quote Originally Posted by Mikey Bonefas View Post
    i would love to know about it!! Could you give me more info?
  14. #14 Re: Rust on gtp!
    Madrid Iowa
    Thanks Mikey
  15. #15 Re: Rust on gtp!
    Madrid Iowa
    good to know thanks alot (:
  16. #16 Re: Rust on gtp!
    Madrid Iowa
    do you know where i can get rocker panels?
  17. #17 Re: Rust on gtp!
    Antioch, IL
    ebay, rock auto. sand blast that ****, weld in a panel, and seal that ***** up so it dont rust again.
    2009 Challenger SRT8
    Expert at being gay.
  1. Rust
    By darionmilton in forum Visual/Body Modifications
    Last Post: 04-21-2012, 01:05 PM
  2. Gas cap rust.
    By cameron92 in forum Visual/Body Modifications
    Last Post: 01-11-2012, 11:05 PM
  3. Rust!!! :(
    By Bluemagic in forum Visual/Body Modifications
    Last Post: 09-26-2011, 11:50 PM
  4. Rust!!!!
    By E IN v Y in forum Visual/Body Modifications
    Last Post: 08-14-2011, 03:41 PM
  5. RUST!
    By Taz Magister in forum Brakes/Suspension/Chassis
    Last Post: 03-17-2011, 01:09 PM
