Thread: Cylinder 3 misfire when SC would kick in
Results 1 to 2 of 2
  1. #1 Cylinder 3 misfire when SC would kick in
    GT Level Member Beelzeboul's Avatar
    Racine
    so my idle vacuum and ltfts are all back in order after my header installation but im having an issue getting a misfire and ses code for it anytime I open the throttle up enough that the supercharger would kick on
    was told its probably just a tuning issue with the flo mods I added was also told 3 and 5 tend to run the leanest so if I'm running lean thats where the problem would normally present itself .
    Just wanted to see if any damage could occur driving it before getting it tuned so long as im easy on the gas ?
    and to confirm its most likely a tuning problem caused by either the massive flow increase or the colder plugs
    mods to date
    t-stat 180 , SD headers , EGR delete , Cat+resonator Delete , Intake , tr6 ngk Plugs(-1heat range)
    I'm sorry officer I didnt know I couldn't do that
  2. #2 Re: Cylinder 3 misfire when SC would kick in
    Nope, sorry. I've already made suggestions in another post about this issue. Please continue in that post.
  1. Possible cylinder misfire
    By TopGunSalo in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-03-2010, 02:57 AM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
  5. GTP with misfire at higher rpms or when boost starts to kick in
    By 00obgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2009, 05:27 PM
