Thread: AC will start on defrost position
Results 1 to 5 of 5
  1. #1 AC will start on defrost position
    Apr 2009
    Kitchener, ON
    I have 2003 Pontiac Grand Prix and the AC starts to blow cold when I switch to defrost position even the AC button is off. When I move the fan switch to blow in front the AC is disconected. What can it be?
    Thanks,
    Mircea
  2. #2 Re: AC will start on defrost position
    Denver
    It's wired this way. Cold air has less capacity to hold moisture - I think pretty much every car turn on the AC when you're in defrost.
  3. #3 Re: AC will start on defrost position
    yup a/c works when the defroster is turned on. and any heat setting it seems on my car.
    this is why i pull the relay for the a/c compressor every winter. i see no reason for it to be running at all, and have no issues doing so.
  4. #4 Re: AC will start on defrost position
    Denver
    The only reason I like this 'feature' in the winter is it keeps the system lubed year round.
  5. #5 Re: AC will start on defrost position
    Apr 2009
    Kitchener, ON
    I haven't noticed this before, maybe because I can hear now better as car gets older when the compressor gets engaged Thanks for your replay.
  1. Ignition will not turn to start position
    By glovey in forum General Tech Discussion
    Last Post: 08-08-2011, 03:51 PM
  2. Defrost Issue
    By GreyGhost in forum General Tech Discussion
    Last Post: 12-27-2010, 10:35 PM
  3. Replaced Crankshaft position sensor, now won't start
    By 03grandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2010, 09:22 AM
  4. A/C Turns on when i switch to defrost
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 08-29-2009, 10:51 PM
