Thread: help me install my boost gauge!
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 help me install my boost gauge!
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hey guys, about half way through my boost gauge install.
    couple questions.
    1) is reading of 15-16 hg normal for vaccum?
    2)I tapped in with a T under the supercharger snout. However there is a vac cable that goes into the snout T and one cable that comes out of the snout T which leads to the bbv if Im not mistaken. I tapped in with a T "after the snout" so in between the bbv and the snout T. Is this fine to read boost and vac or should i change it to tap into before the snout T??
    3)should it read boost in park?? don't think it was didnt get a chane to drive it yet. my dic gauge has always read full bars.
    if anyone can help me out here i'M almost done!
  2. #2 Re: boost gauge intall?
    Yes you can read boost in park.
    You should actually "T" it in under the MAP sensor on the back of the supercharger vac lines, not under the snout.
  3. #3 Re: boost gauge intall?
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    ^ is there a reason for that? or just to save line when you run it back into the car?
  4. #4 Re: boost gauge intall?
    May 2011
    Ontario
    Quote Originally Posted by blueguy91 View Post
    where is this? srry first time installing a gauge. also it is 04 gtp dont know if that matters
  5. #5 Re: boost gauge intall?
    follow the vac lines to the backside of the supercharger.
    The MAP sensor is a black 3wire sensor bolted to a bracket.
    "T" into the vac line that runs to it.
  6. #6 Re: boost gauge intall?
    Quote Originally Posted by blakgtp View Post
    Yes, because that is the proper location for a reading.
    Everything else is gonna get poopoo skewed.
  7. #7 Re: boost gauge intall?
    May 2011
    Ontario
    also currenly where i have it "t"d it shows 15-16 vac is this normal? thought it should be around 20. thanks
  8. #8 Re: boost gauge intall?
    It should be around 19-20
    Hence my post about being the proper location.
  9. #9 Re: boost gauge intall?
    May 2011
    Ontario
    okay will try this tomorrow.
    thanks boss.
  10. #10 Re: boost gauge intall?
    yuuuuuuuuuuuuuuuuup
  11. #11 Re: boost gauge intall?
    Jan 2012
    Philadelphia
    thanks as well! ill be putting mine in the right place when i get the time
  12. #12 Re: boost gauge intall?
    around 20~ with a stock valvetrain that is.
    And no vac leaks, lol.
    Ohio
    Boss?
    Heh
  14. #14 Re: boost gauge intall?
    Yeah.
    Let's go there, cats.
    Ohio
    So where should I tap a vacuum line in for the boost gauge on my gt? I heard it pushes so much boost it actually doesn't read past 0
  16. #16 Re: boost gauge intall?
    That's what we call a vacuum gauge, Hoover.
  17. #17 Re: boost gauge intall?
    May 2011
    Ontario
    i also have a p0135 i can't get rid of. tried everything, heard a vac leak can trigger this code...if that the case bad timing on the gauge instsll to have a vac leak
  18. #18 Re: boost gauge intall?
    I think that's an o2 code.
    Can't recall.
    Too lazy to look.
  19. #19 Re: boost gauge intall?
    May 2011
    Ontario
    yes it is front 02 sensor heater bank 1...replaced sensor, ran diagnostics..everything looks good still getting a p0135 code.....BS
  20. #20 Re: boost gauge intall?
    Now diagnose it.. Look up the code and check the heater circuit fuse.
    As for the vacuum line. It doesn't matter where you T into the line. You need to be hooked in anywhere on the horseshoe of line from BCS to FPR to LIM to MAP. Doesn't matter a bit where in that line you tap in. Not sure why Blueguy was pushing you to put it in a nice clean location vs making a mess under the snout.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
