The harness is routed through gaps in the motor mount brackets, can I get the connectors through without removing the mounts or do I need to support the engine and take the mounts off? Has anyone had to do this?
Remove the 15mm nut/bolts that hold the dogbones to the motor and those mounts. Then take out the 4 13mm bolts per mount to remove the mounts. You will not get the harness out w/o pulling them.
