Thread: rpm hand not moving
Results 1 to 20 of 22
  1. #1 rpm hand not moving
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok i searched and couldnt find anything and wasnt for sure were to post this at but when i turn m 00 pontiac gp gtp switch over as normal my rpm hand and speed hand jumps as normal and like the others,but when i crank it,it dosent move,what could it be?
  2. #2 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    You've left out some vital information.
    Does the car start?
    If it does start, does the gauge deflect to expected rpm?
  3. #3 Re: rpm hand not moving
    Jul 2010
    yes the car runs,drives everything and no it dosent move when started but jumps when you turn the switch to on like all the other hands do
  4. #4 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    If it passes the test procedure with key on then I would think that the signal is not getting to PCM from the crank sensor. The stepper motor is obviously working. This is kind of confusing because the car theoretically should not run.
    Maybe someone else has an idea.
  5. #5 Re: rpm hand not moving
    Jul 2010
    i cant find anything on google but someone told me it may be something in the coil pack,could it be?
  6. #6 Re: rpm hand not moving
    I'm sitting back waiting to see if the needle moves with rpm. You said it doesn't move when the car is cranking.. nothing about once it's started.
    Can you clarify please.
  7. #7 Re: rpm hand not moving
    Jul 2010
    when the car is started/fully running it dosent move with rpms
  8. #8 Re: rpm hand not moving
    Ok.. and next question. Your user name says 94 GP, do you actually drive a 94?
    You gave us very little info dude.
  9. #9 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    It's a 2000.
  10. #10 Re: rpm hand not moving
    Jul 2010
    i did and when i first posted i put when i turn my 00 pontiac gp gtp switch over as normal all the hands/needles move/jump as normal but when the car is started/running the rpm needle dosent move,im not sure what else to say
  11. #11 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    Bill
    If there's four wires that go into the CKP then I would suspect that there are two output waveforms?...One for the PCM and one for the cluster?
    EDITED: Maybe one for PCM and one that goes to the ICM.
  12. #12 Re: rpm hand not moving
    ehhhh damn laptop screen at work. it was off the screen and I figured there wasn't anything valuable there.. sorry man.
    Ok.. hmmm can you scan the car for rpm? If so..that'll tell you if you are getting rpm to the pcm which would mean a bad connection somewhere from there to the cluster. If not, just swap your crank sensor and hope for the best.
  13. #13 Re: rpm hand not moving
    Quote Originally Posted by Rico View Post
    Bill
    Part 1 -GM 3.8L Ignition Module Test and Crank Sensor Test (3X, 18X)
    More information than you probably wanted to know.
    Backup to here for more fun: http://easyautodiagnostics.com/index...articles_1.php
  14. #14 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    Thanks Matt!
  15. #15 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    So he should test continuity from the white wire to the cluster?
  16. #16 Re: rpm hand not moving
    or..test to see if there's a pluse comeing out of whitey.
  17. #17 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    If there's no pulse then it's probably just the CKP.
  18. #18 Re: rpm hand not moving
    Did you guys see what feeds the signal to pcm.. or is it calculating off the 3 and 18?
  19. #19 Re: rpm hand not moving
    AFAIK, it switches based on engine speed.
    Low speed uses the higher signal, high speed uses the lower signal.
  20. #20 Re: rpm hand not moving
    Apr 2009
    Fort Worth TX
    So then it can't be the CKP. Maybe there's no signal from the ICM out to the cluster.
    I never thought the ICM could be the source of this problem. Never had to think about it though.
  1. Probably Moving On
    By nault31 in forum General Grand Prix Discussion
    Last Post: 06-18-2012, 06:56 PM
  2. Moving to VA
    By fireprix in forum Southeast
    Last Post: 01-12-2012, 11:19 PM
  3. Moving the PCM
    By Jakescoots in forum General Tech Discussion
    Last Post: 10-21-2010, 04:57 PM
  4. Moving on............
    By 07CrimsonGT in forum Introductions/Noob Questions
    Last Post: 04-14-2010, 09:56 PM
  5. Moving from a 97 to 04?
    By Infinity9999 in forum 04+ Specifics
    Last Post: 07-28-2009, 09:33 PM
