Thread: harmonic balancer removal
Results 1 to 19 of 19
  1. #1 harmonic balancer removal
    Jun 2012
    baltimore
    I read the how to post to change my crankshaft position sensor... one step is to remove the harmonic balancer. How can I get that bolt out? I try and loosen it and the whole crank spins...am I doing something wrong... help would be great I was reading that people put a breaker bar on and jammed it into the ground and cranked the motor. Is this how I need to do it?
  2. #2 Re: harmonic balancer removal
    people use a like a vise grips on the flywheel to stop it from moving.
    Impact gun is the easy way.
    SE Level Member silvapain's Avatar
    Jul 2012
    Kankakee, IL
    Jack up car and pull RF wheel. Put a socket and a breaker bar on the crank bolt, and put the handle of the breaker bar against the ground. Have a buddy floor the gas and start the car (flooring the gas will stop the car from actually starting). The starter motor will break the crank bolt loose for you.
    Tapadatass
    Last edited by silvapain; 08-04-2012 at 01:38 PM. Reason: iPhone spellcheck sucks harder than a crackwhore that needs $5 for her next hit
  4. #4 Re: harmonic balancer removal
    Pennsylvania
    Quote Originally Posted by silvapain View Post
    Jack up car and pull RF wheel. Put a socket a breaker bar on the crank bolt, and put the handle of the breaker bar against the ground. Have a buddy floor the gas and start the car (flooring the gas wi stop the car from actually starting). The starter motor will break the crank bolt loose for you.
    Tapadatass
    A safer way to stop the car from starting might be to just unhook the fuel pump fuse/relay, or disable spark
    Sport Edition Kv5 18x8
    Jul 2012
    Kankakee, IL
    Quote Originally Posted by FriboRage View Post
    Both those ways would definitely work well.
    Tapadatass
  6. #6 Re: harmonic balancer removal
    Jun 2012
    baltimore
    That's the **** I'm talkin about fellas. Thank you.
  7. #7 Re: harmonic balancer removal
    Lmao simple but effective way to get it done .
    04 Comp G.
  8. #8 Re: harmonic balancer removal
    Jun 2012
    baltimore
    So gettting that bolt out was cake walk...now how do I get the d*** thing off. I read the how to on fixing my crankshaft position sensor it basicall just says you have to remove the harmonic balancer... ok I got the center bolt out I hooked up the duck foot puller and screwed in the center screw and nothing...I admit I'm a new guy at this I've never done this before but I'm in the home stretch now I just need to get the balance off and it will not budge an inch... please help before I just set fire to my car and call it a day
  9. #9 Re: harmonic balancer removal
    Omaha, NE
    Go and either rent or buy a pulley puller, and follow the instructions.
  10. #10 Re: harmonic balancer removal
  11. #11 Re: harmonic balancer removal
    Jun 2012
    baltimore
    I have one...no instructions but I have the kit...I read online that you need to use the duck foot piece, screw in the 3 screws to the balancer through the duck foot piece, then screw in the center screw....well it still wouldn't budge and I almost had the center screw all the way in.
  12. #12 Re: harmonic balancer removal
    try tapping the large center bolt when its tight, sometime a good rap will bust it free. of the puller that is.
  13. #13 Re: harmonic balancer removal
    Omaha, NE
    You have to make sure you have the right size screws for the 3. I had to use some different than what my puller came with.
    You have to use force once the middle bolt touches the balancer bolt (which should be loosened almost all the way out) and just keep going. It will pull out.
  14. #14 Re: harmonic balancer removal
    Jun 2012
    baltimore
    I read that how to article... but no where does it give the new guy...such as myself... an exact explaination on how to get the balancer off once the center bolt is out. I hate to put all this back together with out fixing the problem.
  15. #15 Re: harmonic balancer removal
    Jun 2012
    baltimore
    Yea I went and bought the m6 1.00 75 mm in length bolts. They weren't in the kit. I just feel like I'm doing something wrong the center screw was pretty much all the way in and the balancer did not move at all.
  16. #16 Re: harmonic balancer removal
    Jun 2012
    baltimore
    Ok so this might be a dumb question and perhaps where I messed up. I need to keep the balancer bolt in there and screw the puller bolt down on to the balancer bolt?
  17. #17 Re: harmonic balancer removal
    the bolts needs to be out.
  18. #18 Re: harmonic balancer removal
    Take a pic of how you have it set up
  19. #19 Re: harmonic balancer removal
    Jun 2012
    baltimore
    I got it! Just took a beating. I was afraid to hit it I was sure if I would damage anything the pusher rod was in as far as I could turn but tapped a few times and got it...I had a torch and gas ready!
    Now its off to try and remove this plastic piece without breaking it
  1. Harmonic Balancer Bolt Removal
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2012, 09:35 AM
  2. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  3. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  4. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
