Thread: 97 to 05 seat connector
Results 1 to 6 of 6
  1. #1 97 to 05 seat connector
    Feb 2010
    TN
    Can I just cut the connectors off my old 97 seats and attach the to the 05 seats then plug them in or no. the 05s, have heat and power lumbar old seat were cloth manual lumbar, no heat
    Quincy, Mass
    Sorta, you'll need to make sure the heaters have there own power and a switch. And you'll need to splice in power for the passenger heat and a switch. The 04+ heated seats are also controlled by the bcm, the 97-03 are controlled by a sensor. So unless you swap the entire harness inside 2 97-03 heated seats you'll just need to turn the switch off when your ass gets hot
    No more GP 04 Impala SS Indy:
  3. #3 Re: 97 to 05 seat connector
    Feb 2010
    TN
    will the lumbar have to be wired to a switch as well?
    Quincy, Mass
    Lumbar is part of the regular seat adjustment switches for power, so as long as they get power the lumbar will work.
  5. #5 Re: 97 to 05 seat connector
    Feb 2010
    TN
    Thanks swiggles
    Quincy, Mass
    No proplem
  1. right connector?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-03-2010, 10:03 PM
  2. Where does this connector go?
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2008, 09:34 AM
