Thread: Lower mounts & mounts spacers
Results 1 to 20 of 20
  1. #1 Lower mounts & mounts spacers
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    so is my lower engine mount busted or what!? where is the best place i can get solid tranny and engine mount? and while im in there i was thinking of also installing the mount spacers Vinnie sells. do u guys recommend the spacers?
  2. #2 Re: Lower mounts & mounts spacers
    Yeah motor mount seems shot. You shouldn't need spacers unless your lowered or intercooled.
    Jul 2012
    California
    yea im lowered and i have slight vibration in the front when accelerating. the mount on the tranny side looks messd up also. do AutoZone or Napa carry solid mounts?
  4. #4 Re: Lower mounts & mounts spacers
    I know autozone does but you have to ask specifically about it.
  5. #5 Re: Lower mounts & mounts spacers
    Minnesota
    Mount spacers for lowering and cradle spacers for hood clearance are very different things.
  7. #7 Re: Lower mounts & mounts spacers
    Yeah I thought about that after I posted it.
  8. #8 Re: Lower mounts & mounts spacers
    Jan 2009
    Tallahassee, FL
    I made my own spacers, did the trick
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #9 Re: Lower mounts & mounts spacers
    Solid mounts from rockauto. Cradle spacers from Vinnie...easier to do when you change the mounts.
    04 Comp G.
    Jul 2012
    California
    will check out rockauto for mounts. l need mount spacers from vinnie not cradle spacers..i don't even think vinnie sells cradle spacers. thanks though
  11. #11 Re: Lower mounts & mounts spacers
    cradle spacers do not come from vinnie and they move the cradle DOWN to LOWER the motor/trans.
    engine/trans mount spacers move the engine UP.
    Typo meant cradles spacers from zzp..and lowering spacers from vinnie.
    Sent using Tapatalk.
    04 Comp G.
    I figured. Just don't want to have people confused and start saying the wrong things.
    Jan 2009
    Tallahassee, FL
    You can make your own pretty easy. I used some 1/4" scrap steel from work, cut it out into 1" squares, and drilled something like a 1/2" hole in each of them, and I had my spacers.
    77 Morris Garage B
    Jul 2012
    California
    Quote Originally Posted by Sandman View Post
    good idea..i will look into that
    Jan 2009
    Tallahassee, FL
    Or even easier you can buy thick square washers, they may be a little big
    77 Morris Garage B
  17. #17 Re: Lower mounts & mounts spacers
    you could always just use washers, too.
    you wouldn't be the first person to stack washers to make a spacer. and you wouldn't be the last, either.
    Jul 2012
    California
    yall are starting to convince me on stacking washers. its 3/4" of height to add, right? ..atleast that's what i think the spacers add
  19. #19 Re: Lower mounts & mounts spacers
  20. #20 Re: Lower mounts & mounts spacers
    Minnesota
    Depends on how big the washers are. Otherwise you are just going to make the mount go out even faster.
  1. Installing new Tranny and Engine Mounts w/ Vinnie's cradle spacers
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 10-31-2016, 08:20 PM
  2. trying new mounts
    By Z34Phoenix in forum General Tech Discussion
    Last Post: 01-19-2012, 04:26 PM
  3. mounts
    By rossscrappy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2010, 06:03 AM
  4. mounts
    By gtboy2000 in forum How To Write-Ups/Tech Tips
    Last Post: 06-05-2010, 10:28 PM
  5. Symptoms of bad lower tranny/engine mounts
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2010, 03:40 PM
