Thread: Car won't run and I am stuck out of state.
Results 1 to 6 of 6
  1. #1 Car won't run and I am stuck out of state.
    Jul 2012
    I have a 2002 Pontiac Grand Prix n/a 3800 Series II. Has approx 77,000 miles on it. I've owned it the past year and a half and had no real issues with it.
    I traveled out of state, 4+ hours from home to visit family. Car has been fine until Tuesday when we went to leave. We drove about 25 mins and stopped for a quick dinner. Tried to restart and it wouldn't start without giving it lots of throttle and it running overly rich. Black smoke from tail pipes. Had it towed back to the house to look at it Wednesday morning. It fired up and ran perfect in the morning. I drove it to a gas station filled up and then back to the house with no problems. Loaded everyone back in the car and the same issue. Hard start, have to hold the throttle running rich until it just won't stay running at all. Symptoms get progressively worse.
    We cleaned out the IAC which seemed to help, but the engine had cooled at this point. Get ready to leave and same issue.
    It starts and runs fine when cold, but once turned off after warm up it doesn't want to run.
    We replaced the Crank Position Sensor after searching the forums here, along with the Ignition Control Module. No change. No codes have been set. We scanned it with a basic hand held and the TPS shows like it's working, the ECT reads normal. There was possibly an issue with no reading from STFT on one of the O2 sensors but the car may not have been running long enough to enter closed loop.
    The only other symptoms are the PCM doesn't seem to be setting codes at all. We unplugged the EGR and the MAF to see if that changed symptoms and no codes were set.
    Also the air motor, in the aircleaner box seems to be sticking and blowing the underhood fuse.
    We are now thinking that possibly this is supposed to help cool the PCM and isn't and the PCM itself is failing.
    Any help would be greatly appreciated as I am using up vacation days and need to get home ASAP. I am supposed to be moving this weekend. Thanks.
  2. #2 Re: Car won't run and I am stuck out of state.
    When you unplugged the maf, you say it didn't set a code... how did the car act?
    This sounds like a fuelling issue. Therefore a stuck injector, maybe, but I'd expect a code and only one cylinder showing a misfire. Or maf sensor. O2 sensor even unplugged won't cause this issue.
  3. #3 Re: Car won't run and I am stuck out of state.
    GT Level Member Toms04compg's Avatar
    Michigan
    So it runs fine no sputter or anything until it decides it doesnt want to start?
  4. #4 Re: Car won't run and I am stuck out of state.
    Jul 2012
    Car didn't seem to show any difference with MAF unplugged... it was reading some air flow which would change according to the throttle on the scanner but I'm not sure what values would be correct.
    Yes it would run and drive fine with normal power until a warm restart. Then it would act up.
    It was hard to start this morning with a flashing SES for a misfire, which at this point probably means fouled plugs from too much fuel last night.
  5. #5 Re: Car won't run and I am stuck out of state.
    Read the code.. if it's one or two cylinders..you have something to go on. Otherwise.. there's only a couple things that control fueling.
    MAF and PCM are the two biggest contributors
  6. #6 Re: Car won't run and I am stuck out of state.
    Connecticut
    Just wanted to follow up on this. It was my car.. couldn't remember my log on etc and had no email access blah blah blah. It ended up being a bad MAF sensor. We fixed a few other problems like some melted wires but the car runs fine now and made the trip home finally.
  1. Washington State
    By nutcase in forum West
    Last Post: 06-26-2016, 10:04 AM
  2. Tri-State Raceway Aug. 4th
    By fisher580 in forum Midwest
    Last Post: 07-25-2012, 07:03 PM
  3. Car stuck in park, key isn't stuck though
    By capitalcrew in forum General Tech Discussion
    Last Post: 05-03-2012, 10:28 PM
  4. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  5. state with the most members?
    By jpe in forum Off Topic Discussion
    Last Post: 07-28-2011, 08:33 AM
