Rico whats this milly lube stuff for the head bolts?... What does it do and should i remove bolts and use it?
Molybdenum based engine assembly lubricant. You can get it at your local parts store.
Warning: Don't put it on anything but bolts that require specific torque. If you put it on bearings it'll trash them.
Yes, remove the bolts, lube and retorque to spec. Make sure to put a little on the underside of the bolt head where it comes in contact with the head.
They are fine Tom.. listen to old man Chuck. He even knows how to use plastigauge.
