Thread: Misfire #6
Results 1 to 12 of 12
  1. #1 Misfire #6
    Jul 2012
    Marietta, Ga
    Have a Misfire code and the Fuel Inject code on my 1999 Grand Prix (3.8).. I replaced the injector, did a full tune up, wires, plugs, fuel injecting cleaning, and even a tranny filter and gasket change. After a day or so, it started to run rough and threw the same codes..... I was reading that sometimes it can be a ground issue.... I can say that the main ground going from the batter to the car was poor.... it was grounded to a painted surface.... I corrected that ... Now my Low Coolant light came on.... well kinda off and on... now on all the time.... I replaced that module in March..... plenty of coolant and levels are good.... its acting like a ground... can anyone tell me where the main harness ground for the Low coolant module is?????
  2. #2 Re: Misfire #6
    coolant sensor gets gunked up and its pretty easy to just unhook it.
  3. #3 Re: Misfire #6
    Why wouldn't your battery ground be on the correct stud at the transmission? Maybe move it back where it belongs with the other two grounds and see if that helps.
    On that injector...what is the code?
  4. #4 Re: Misfire #6
    Jul 2012
    Marietta, Ga
    I didn't move the ground.... I just unscrwed the cable and cleaned it up. Ill see if I can get a pic.... It terms of the coolant light... I will remove/clean/replace, but it really acts like an electrical problem... Light doesn't stay on... it fades in and out... very strange.... Thanks for the suggestions... The code was PO206---- the other code was a 300 code..... Misfire on #6... same as my fuel injector
  5. #5 Re: Misfire #6
    p0300 is a random misfire code not a cyl 6 misfire code.
  6. #6 Re: Misfire #6
    Jul 2012
    Marietta, Ga
    The scanner I have identfies the cyl. It was confirmed byt dealer
    Test resistance across the injector. Should be around 15 ohms.
    Quote Originally Posted by rnpiii View Post
    P0306 is cyl 6 misfire.
  9. #9 Re: Misfire #6
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  10. #10 Re: Misfire #6
    Jul 2012
    Marietta, Ga
    Y’all are correct PO306 and I test the injector... was week... cleaned the connector and put a small amount of electrical grease... then test correctly.... did that this am... dove 20 miles and so far so good........
  11. #11 Re: Misfire #6
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Any further trouble since your last post? All good?
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  12. #12 Re: Misfire #6
    Jul 2012
    Marietta, Ga
    Everything working fine. Since the rewiring, the motor runs as it should & has not produced a code.
  1. misfire??
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2012, 12:49 PM
  2. Maybe a misfire?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2010, 04:24 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. 99 GT Misfire on cyl 6.
    By mazzafamily in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2009, 10:12 AM
  5. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
