Thread: Where to buy an evaporator drain elbow?
Results 1 to 9 of 9
  1. #1 Where to buy an evaporator drain elbow?
    May 2008
    Anyone know somewhere where I can buy the evaporator drain elbow online? Is it only available through the dealer?
    Thanks,
    Steve
  2. #2 Re: Where to buy an evaporator drain elbow?
    May 2008
    Does anyone have any input on this? Also, what is the part number for the drain elbow?
  3. #3 Re: Where to buy an evaporator drain elbow?
    May 2008
    Finally found it, and replying here in case anyone needs it in the future.
    OEM# 22697948
    Delco# 1533323
    At RockAuto: http://www.rockauto.com/catalog/moreinfo.php?pk=887465
  4. #4 Re: Where to buy an evaporator drain elbow?
    Aug 2011
    Bucks County Pa
    I just had my evaporator drain elbow clog on me.
    It was a small stone that made it clog.
    Because of it passenger side rug wet again!!!
    Do your self a favor and cut the opening a little larger.
    George
  5. #5 Re: Where to buy an evaporator drain elbow?
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    I'm glad i saw this post. , I have the same problem rt now. Couldn't figure out what was leaking .... Now I know what to look for. Thanks
    04 GT1
  6. #6 Re: Where to buy an evaporator drain elbow?
    PALMDALE CA
    A, where is this thing?? Is it inside where the heater core is?? And can it just be cleaned out or changed??? I never had to deal with one YET.
    04 GT1
  7. #7 Re: Where to buy an evaporator drain elbow?
    Feb 2010
    TN
    Got mine at the junk yard
  8. #8 Re: Where to buy an evaporator drain elbow?
    Aug 2011
    Bucks County Pa
    Quote Originally Posted by PALMCASTER GT1 View Post
    Located behind the power steering pump on the firewall.
    Its a small rubber L shape plug. Just remove your overflow
    tank and go halfway down the firewall and it should be sticking out.
    Just pull it off and cut the opening a little to make not clog again.
  9. #9 Re: Where to buy an evaporator drain elbow?
    PALMDALE CA
    OK thanks, gonna check that out in awhile
    04 GT1
  1. A/C evaporator 01 GTP, how do we get it out???
    By Bunnystac in forum General Tech Discussion
    Last Post: 06-22-2012, 03:57 AM
  2. Evaporator Control Valve
    By 00Kevin in forum General Tech Discussion
    Last Post: 05-31-2010, 10:34 PM
  3. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  4. Evaporator Drain Location?
    By 05pontiacgprix in forum General Tech Discussion
    Last Post: 01-31-2010, 03:14 PM
  5. Looking for evaporator tubing ends at TB
    By nlinesk8s in forum General Tech Discussion
    Last Post: 01-11-2009, 05:43 AM
