Hello all,
I am new to this forum and would really appreciate your help before I pay someone a ton of money to fix a potentially easy problem.
The issues:
Ac/ Heat do not work unless the switch is on the highest setting. My digital diagnostic display is out (the diagram of the car which shows a door open and also gives you your mpg, distance to empty etc.) and my day time running lights are out.
I saw online the ac and heat issue could be the blower resister but would this also be affecting the lights and electrical? It all happened at once.
If you know what may be wrong, is this something I could fix myself? I am not a mechanic and the extent of my experience is switching out an alternator and basic maintenance.
Thank you so much in advance
Sincerely,
Brian
