Thread: Cast coolant elbow O ring. Other options
Results 1 to 13 of 13
  1. #1 Cast coolant elbow O ring. Other options
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    I took the big one off the extra coolant elbow and put it on the cast one. Went on wayyy to easy. Of course still leakin same spot. Any other options you guys have found in the O ring world that seals a little tighter.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Cast coolant elbow O ring. Other options
    Apr 2009
    Fort Worth TX
    Larger o-ring or RTV are the only options besides getting a new elbow. Personally I would spend the $5 on the new elbow(s).
  3. #3 Re: Cast coolant elbow O ring. Other options
    Minnesota
    Get the OEM elbow and use RTV
  4. #4 Re: Cast coolant elbow O ring. Other options
    He has a 98 which has an elbow cast into the timing cover he can't replace it without replacing the whole cover.
  5. #5 Re: Cast coolant elbow O ring. Other options
    Apr 2009
    Fort Worth TX
    Holy crap, didn't know that.
    Larger O-ring or RTV the crap out of it.
  6. #6 Re: Cast coolant elbow O ring. Other options
    i just did this my self not to long ago. also a 98 GS. i used the O ring off the extra elbow, i also cleaned the crap out of the hole. lubed with a dab of oil and it slid right in, no leaks.
  7. #7 Re: Cast coolant elbow O ring. Other options
    Quote Originally Posted by Rico View Post
    96-98 only have the one coolant elbow. You learn something everyday.
  8. #8 Re: Cast coolant elbow O ring. Other options
    Apr 2009
    Fort Worth TX
    Thanks D
  9. #9 Re: Cast coolant elbow O ring. Other options
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    My 99 has this problem.. It could go for two months and never drip a drop of water, then I could go through a gallon every week.. Frustrating as hell.. I have been through 3 sets of elbows in the past year. I have a set from a local GM dealer now that I am going to change them out while I have the motor apart due to engine fire.. I'm going to use the oil idea and lube up the holes some so the rings may seat better AND I'm going to use some black RTV.
    One question I have about the RTV is should you just put a bead around the o-ring then push it in, or once you get the alternator bracket back bolted down should you squeeze the RTV around the gap then?
  10. #10 Re: Cast coolant elbow O ring. Other options
    Oct 2008
    IL
    I put a thin layer of copper RTV in the groove where the O ring goes to raise out the ring a little. Seem to be good now. If not then I'll RTV evvvverrrryyyything and the O ring itself its a super easy job so im not to worried just annoyed. Yes 98 has the cast elbow it's a love hate thing.
  11. #11 Re: Cast coolant elbow O ring. Other options
    Apr 2009
    Fort Worth TX
    What keeps these from sealing is that people don't clean the hole where the o-ring seats.
    I use 400 grit sand paper...put it back together (new elbows) with a coating of plumbers silicone sealant and hadn't leaked for over 50K.
    The aluminum corrodes right where the o-ring is supposed to seat. It's a white powdery mess. Clean it up and it will seal.
    As far as the RTV goes: put a light coating on the inside of the hole and a coating on and around the o-ring and put it together. Many people have had good luck with the RTV.
  12. #12 Re: Cast coolant elbow O ring. Other options
    Oct 2008
    IL
    I'll try that ^^ if it happend again. Sounds like a good process.
  13. #13 Re: Cast coolant elbow O ring. Other options
    I use fine steel wool. It's all good either way. However if you still have a leak, then you should look at the timing cover closely. The reason GM changed to both being plastic is the timing cover breaks easily when you pull/push on the tensioner the wrong way during disassembly.
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. coolant elbow specs
    By boostedcompg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 10:02 AM
  3. o-ring on steel coolant elbow????
    By BlackGT97 in forum General Tech Discussion
    Last Post: 10-04-2011, 11:17 AM
  4. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
