Thread: Ac condensation
Results 1 to 5 of 5
  1. #1 Ac condensation
    Jun 2012
    Kansas
    Has anyone had a issue when u run you ac there is condensation below the ashtray. Water collects on the center console.
  2. #2 Re: Ac condensation
    May 2012
    goldsboro nc
    im getting the condensation in the passenger foot well but I have no idea why
  3. #3 Re: Ac condensation
    Apr 2009
    Fort Worth TX
    The drain system for the evaporator is probably clogged.
  4. #4 Re: Ac condensation
    GTP Level Member
    springfield IL
    Quote Originally Posted by Rico View Post
    Where is the evap can??? Is it fairly easy to change...??
  5. #5 Re: Ac condensation
    Apr 2009
    Fort Worth TX
    All of the condensation that collects on the evaporator makes it's way outside the via a tube that runs out of the firewall and downward toward the rack and pinion. Have you ever noticed the puddle of water underneath your parked car on a hot humid day when you've been using the AC?
    You have to unclog this tube. A vacuum pump works great!
  1. Condensation?
    By Speedy1973 in forum General Tech Discussion
    Last Post: 05-15-2012, 09:56 PM
  2. condensation
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 02-20-2010, 12:37 PM
  3. Any way to remove condensation
    By NewPrixOwner666 in forum Visual/Body Modifications
    Last Post: 06-24-2009, 06:24 PM
  4. Condensation in headlights?????
    By kenneth74gt in forum General Tech Discussion
    Last Post: 05-29-2009, 11:06 PM
  5. water/condensation in tailights
    By scottie2hottie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2008, 05:50 PM
