Thread: Engine Harness
Results 1 to 9 of 9
  1. #1 Engine Harness
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Long story short, I had an engine fire, buring the top of my motor along with the harness and got into the fuel rails a little.. Not bad, but I am in the process of replacing parts and have come across a snag. I don't want to splice into a harness and I want to find the correct engine harness for my car. I have a 1999 Grand Prix GT 3800 N/A. So far I have found a 2001 and 2002 Grand Prix from Morad that I can get for $170 shipped. I have found local a 1999 Buick (not sure the make) but it's got a 3800 N/A motor in it and I can get it for $100.
    How year and car specific are these harnesses? Am I better off at getting the 01-02 GP harness as opposed to the 99 Buick harness? I have heard and read everything and just want to know what would be easiest to put back in and any help would be appreciated.
    If you have other questions please let me know and I'll answer what I can to help.
    None of those gp ones will work. Injector connectors are different.
    Pre 01 are the only years that will work IIRC.
    Unsure if 97/98 will work but that regal harness should be fine.
    Maf was different in 97/98. Unsure if they have the same connector. I think they do but im not sure.
  3. #3 Re: Engine Harness
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
    "Pre 01 are the only years that will work IIRC."
    My 01s Injector connectors are different then my 99s Injector connectors.
    Yes, 99 is minitimer, 01 is multec.
  5. #5 Re: Engine Harness
    Sep 2011
    Decorah IA
    I know I was just trying to help confirm your post.
  6. #6 Re: Engine Harness
    Nov 2009
    Tennessee
    Sounds like I'm about to go put half down on the 99 Buick harness so they can start pulling it out!!! I appreciate all the info!!!
  7. #7 Re: Engine Harness
    Nov 2009
    Tennessee
    ERRRRR Regal Harness was slightly different, to close to tell when I was looking at the salvage yard!!!!!!! Crap, There are three plugs.. I'm going to strip down my GP harness to see if I can see what I can do.. If not, anyone need a 99 Regal 3800 NA Harness? LOL
  8. #8 Re: Engine Harness
    Nov 2009
    Tennessee
    Ok.... Found a 98 GT harness from Morad... They sent me several pics and all looks right, but I have not messed with harnesses... Any info on the 98 vs 99, MORAD couldn't tell me a difference? If it is just fuel injector connectors, I have two sets of connectors that I can splice what I need on, I just don't want the ABS to be different or something important missing that needs to be there.. LOL ANY help or directions would be appreciated.
  9. #9 Re: Engine Harness
    Nov 2009
    Tennessee
    There are slight differences in the 98 harness and my 99 (as seen in the pics) Can anyone tell me where I can find pin configurations online? I can not find anything.. Anyone had any luck moving pins? Any help would be appreciated, I'd like to purchase a harness and get my car back on the road, tired of driving my project car around!! LOL
    In this pic you can see where the block screws into the back of the fuse/relay panel that mounts on the pass side strut tower the one pin is moved and two others on the 98 harness are NOT on my harness. if I knew where these went to I could better judge if this harness will work. The one that is existing on both just moved is a black/white striped wire.
    This is a pic of the ABS module. My 99 is on the left, the 98 from MORAD is on the right. You can see everything is the exact same with the exception of one pin existing on the 98 harness that mine does not have. Any ideas??
  1. Difference in engine harness for 97 GTP vs 98 GTP
    By kc50lx in forum General Tech Discussion
    Last Post: 04-17-2013, 10:04 AM
  2. engine wiring harness
    By xBlacKxGTPx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 07:26 AM
  3. 98 gtp engine wiring harness
    By doyleQ in forum Wanted To Buy - Parts
    Last Post: 03-03-2012, 01:12 AM
  4. Engine Harness Replacement
    By grandprixgtcv3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-19-2009, 01:04 AM
