Thread: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Quote Originally Posted by selym17 View Post
    can u rewire the pump to a push button switch mounted somewhere by your steering column? and then whem you press it only the pump would turn on the you would have to turn the factory switch to make the wipers turn on, correct?
    Honstly im cheap and i just want it to spray, dont care how lol
    that could be done real easy like. you just need to cut the wires at the plug, (leave 4 or 5 inches of wire on the plug end) and run the wires from the plugs pig tail to power and a a switch, do put a fuse on the power line.
  2. #22 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    That's what I'm probably going to do. Just not worth the time/effort to try to find where the short is, or if the adapter is bad. I just have to make sure the pumps I have are good. I'd be kicking myself if I found out the new pump I bought was bad as well.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  3. #23 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    if you take the pump out and run a neg and pos wire off your battery to the pump, it will buzz/hum when power is added.
  1. washer fluid not working
    By 2000gtp8410 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 05:01 PM
  2. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  3. Windshield Washer Fluid
    By Pontiac99GTP in forum General Tech Discussion
    Last Post: 09-09-2009, 01:35 AM
  4. Fluid pumping out of vent
    By Progas in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2009, 07:37 AM
  5. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
