Hey Everyone,
Did some searches on here, and can't seem to find a definite answer, so I'll create my own thread.
This week Ive began to have a problem where I can turn my a/c on, and its initially cold on the driver side, but then gets hot very quickly while the pass side stays cold. If I adjust the driver side temperature at all (up or down), it gets cold again right away temporarily then hot once again. I should mention I have a trusty 2001 GP with the dual non-digital climate controls.
The threads Ive seen around here point to a blend door actuator on the driver side, but those symptoms all seem to have the actuator stuck/not working at all? My symptoms are different being that the temperature will correctly adjust but only temporarily.
Thoughts? Blend door actuator on the driver side, or are my climate controls going bad and I need to replace the climate dashboard unit? Trying to avoid paying for 2 parts when I only need 1 (hopefully). Thanks ahead of time for any help/responses!
