does anyone have a schematic for the drivers seat heater in a 99?
mine quit working a few days ago and with the colder months coming it sure would be nice if it worked. the switch lights up but the seat dosen't heat.
anyone?
Just because the switch is illuminated doesn't necessarily mean it's functional(pending on how it's wired). Check your fuse first.
The wire should run up the seat post next to the console. Make sure it's still connected and test for volts.
If there is power there you prolly have a seperation up in the seat or right on the other side of the connector.
If nothing there, pull the switch out of the console and test to see if there is volts coming in and out of the switch.
I'm just telling you the process in which I would take to try to solve the problem. I don't have a schematic.
cool, thanks. i'll start there. does anyone know if the FSM contains wiring diagrams? i know some don't and you have to buy them seperate
Hope this helps
webracin
