Thread: Possibly ducting for a custom intake?
Results 1 to 6 of 6
  1. #1 Possibly ducting for a custom intake?
    Jul 2008
    Germantown, Maryland
    3 Inch Automotive Air Intake Ducting - Spectre
    I'm thinking of using ducting similar to this for my custim CAI. It wouldn't uneven spaces in between where the bends would be coupled, and also you can bend it. So you can keep it straight and slightly curved all the way to the fenderwell to minimize the need for a huge bend.
    Suggestions???
    Does Home Depot or any other supply store sell ducting like this? I'm sure they do, just won't be as pretty I'd feel more comforatable with confirmation that they do before I go off searching...
    Thanks in advance!!!
  2. #2 Re: Possibly ducting for a custom intake?
    TDCRacing
    Guest
    Thats def one way....this is another...Will give you better gas milage also...just a suggestion....
    http://www.grandprixforums.net/f49/i...lter-4692.html
  3. #3 Re: Possibly ducting for a custom intake?
    Jul 2008
    nah that's ok... i mean I already have the setup... haha, just need the filter, but thanks
  4. #4 Re: Possibly ducting for a custom intake?
    Feb 2008
    If you're considering going that route, go ahead and get a few 4" aluminum pieces and make a nice FWI for ~$100 including filter. I got a 22* bend and a 6" straight piece and a pair of couplers for $60 through Summit plus the filter from Autozone for $20 (discount) and a roof flashing for a few bucks at Lowe's. I'd go out and take a picture of my setup, but the majority of my engine is strewn about my garage, so maybe in a few weeks...
    But, seriously, that flex tube will probably not flow as well as your current setup, whatever it is. And, it's thin plastic which = major heat soak. Personally, I'd go with a HAI before a flexi 3" FWI. The 4" flexi stuff from Intense or ZZP may be a better bet if you want something flexible.
  5. #5 Re: Possibly ducting for a custom intake?
    Jul 2008
    Quote Originally Posted by DanGTP View Post
    I'll check on that, yea I wanted to try the flexi stuff but wanted to find it in a larger diameter. This stuff is cheap enough to buy some 3inch stuff as well as 4 inch and maybe if time allows i'll check some horsepower ratings with them both...
  6. #6 Re: Possibly ducting for a custom intake?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Im running a 3" tube. it seems to work fine for me.
    Although.... im worried about when it rains
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  1. Vegas anybody? possibly reno?
    By GTPformee in forum West
    Last Post: 01-17-2010, 02:24 PM
  2. water-pump's possibly going out?
    By fst in forum General Tech Discussion
    Last Post: 09-02-2008, 08:49 PM
  3. Quite Possibly the Ultimate in Car Search
    Last Post: 07-29-2008, 01:30 PM
  4. Possibly Add Torque under edit details
    By JashGTP in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 10:22 PM
