Thread: rockers yay or nay?
Results 21 to 40 of 54
  1. #21 Re: rockers yay or nay?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    By the end of the summer I plan to do headers a 3.6" pulley and a intake im considering rockers I don't really want to cam a FWD auto car
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #22 Re: rockers yay or nay?
    Cam > Rockers.
    In everyway.
    Buffalo
    Depends on your set up was in reference to Matt. Dunno why he didn't notice it in HIS set up lol
    Never enough.
  5. #25 Re: rockers yay or nay?
    Nov 2011
    NY
    Never enough.
    Hahaha, that's just the bug getting ya', lol.
    Matt, I have yet to install the YT's (1.9) but will be soon, lol.
    And truly, Cam's without P/P, HEADS & Intakes are a waste too, imho, you'll get good results without it, but not as much with it. So see, it just never ends if you get on that quest for HP...
    Anyways... Sure, go with Rockers if you're not planning to Cam in the immediate future. Whatever you decide, is the right choice, there's no wrong or right here... It's all a matter of opinion and everyone's got one.
  6. #26 Re: rockers yay or nay?
    Oct 2011
    Michigan
    ^^ i agree with you completely and i just wanted to hear everyones opinion on them i know theres things that will net me more HP but i just wanted to know if rockers at least give me some i plan to have other toys so all the money cant go to this one
    one more thing though do i need any new bolts or anything like that when i upgrade the rockers
  7. #27 Re: rockers yay or nay?
    Nov 2011
    NY
    Some interesting reading, fwiw...
    http://www.pontiacstreetperformance....ockerArms.html
  8. #28 Re: rockers yay or nay?
    Oct 2011
    Michigan
    i read this an i imagine the 1.9 ratio rockers from zzp are safe to use with a stock engine which is what i was gonna go with, what are the best/most affordable rockers for my L67?
  9. #29 Re: rockers yay or nay?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    get the Yella Terras, absolute best and they are lightweight, with l76 springs you can rev it anohter couple hundred rpm. and they hold their value the best.
  10. #30 Re: rockers yay or nay?
    Out West
    Quote Originally Posted by addzradd View Post
    Stock cam still limits it.
    Whine with your Cheese?
  11. #31 Re: rockers yay or nay?
    Oct 2011
    Michigan
    Well I really don't want to spend that much, what do you guys thibk of the zzp rockers?
  12. #32 Re: rockers yay or nay?
    Feb 2010
    Cleveland
    Some say ok on those, but i've also heard some stories because they re-use old rockers and re-weld the dimple where the rocker meets it closer to the center, this is bad a. because you have no idea how many miles are on the ones you get and they do have bearings that could theoratically wear out and also, b. because i've heard of a few welds breaking/falling out and causing damage to the pushrods.
    Buffalo
    And you get metal sludge in your oil
  14. #34 Re: rockers yay or nay?
    Oct 2011
    Michigan
    really?
  15. #35 Re: rockers yay or nay?
    Out West
    Metal sludge in your oil means you're winning.
  16. #36 Re: rockers yay or nay?
    Oct 2011
    Michigan
    i dont know which yella tella rockers to get
  17. #37 Re: rockers yay or nay?
    Minnesota
    The aftermarket rockers have a higher fail rate than the stock modified ones. As far as ZZP using used rockers.....Ask them before you buy, but you should be able to tell when you install them if they are extra worn.
    It only would be worth it to get the Yella Terras if you could find a set in the 1.95 ratio. They don't make them anymore so it's going to be few and far between. From what I read the Comp Cams Pro Magnum rockers that ZZP used to sell are the best aftermarket roller rocker, but again they are not made anymore so they will be hard to find.
    Buffalo
    Anyone have a thread containing a failed aftermarket roller rocker?
    Or one about zzp modified ?
    Quote Originally Posted by crazyguy03 View Post
    Ive only heard of harland failures.
    Zzps will wear and have excess play and noise.
    Quincy, Mass
    I loved it when I did 1.9s, really woke the car up! But the cam woke it up alot more. If you don't want to spend all the money on the cam install then definitely do the 1.9s, 105 springs too while your there.
    No more GP 04 Impala SS Indy:
  1. New Rockers and what else?
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2011, 01:30 PM
  2. cam vs rockers
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2010, 08:46 AM
