Hi guys,
Yet again I have to deal with another bizzaire coolant leak on my wife's 2004 Grand Prix. The story goes like this: The coolant resevoir tank had a little leak and was leaving a puddle of anti freeze.
I finally got a new tank and cleaned the inner wheel well and installed the new tank. I filled the tank, started the car, let it warm up, and took it for a test drive.
Upon returning, I didn't detect any leakage around the tank and I figured the problem was solved.
Then I noticed a trail of fluid that run up my drive way and to the car in the garage. I crawled underneath the passenger side and found anti freeze dripping around the rockerpanel area by the sub frame. I wiped it and placed clean cardboard under the area. I got drippings on the cardboard.
Next I got a swivel mirror and my trouble light and looked around the passenger floor area by the bottom of the firewall. It was wet. I also noticed a trail of fluid that ran down the bottom of the passenger side of the car on the outer edge of what would be the frame rails if this car had a frame.
I can't think of any cooling system component that is anywhere near this part of the car. My fear is the heater core has sprung a leak, but it is located in the center of the firewall and I don't detect the typical heater core symptoms such as a smell of anti freeze inside the car or wet carpet.
I took my air gun and blew compressed air around the sub frame cavity and through the openings on the floor/rocker area. Maybe there was a build-up of fluid from the reservoir tank leaking.
I don't think I'm that lucky. Any ideas?
