Thread: Check Engine Light
Results 1 to 4 of 4
  1. #1 Check Engine Light
    Chicago
    I have a 02 GTP and I threw a code today. I got my car scanned and it came up as a P1133 code. It indicated that I had insufficent switching of my fuel ratio. Also said probable cause are: heater circuit, shorted ECM ground, and improper oxygen to sensor. ANY HELP WHERE TO START???????? I have never heard of this but the car seems to be running fine. I dunno what to do and I can really use some help to figure out why it threw the code! Thanks for your guys help I really appreciate it.
    Erick
  2. #2 Re: Check Engine Light
    Hoffman/Schaumburg, IL
    How many miles, your 02 sensor may have just worn out, they get old and fail.... If your above 60k, check the wiring, and if it is ok, then replace the sensor....If you search around online, you can find the sensor for 35-60 bux and it is about 5 - 10 bux at your local auto-parts store for the special socket to make it easier to install remove
  3. #3 Re: Check Engine Light
    TDCRacing
    Guest
    Ahh i found it....
  4. #4 Re: Check Engine Light
    Free Post
  1. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  2. Check Engine Light
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 08:28 PM
  3. Check engine light on
    By darkwingduck in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2008, 07:59 PM
  4. Check engine light and horrible miss...
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 07:53 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
