Thread: Fuel Guage not working
Results 1 to 10 of 10
  1. #1 Fuel Guage not working
    SE Level Member Storm Smith's Avatar
    Mar 2012
    Arkansas
    So I have a 2000 Grand Prix GT that has a broken fuel guage. But the problem is that not just the fuel guage is broken. The resetable trip meter also does not count up. I reset it and it stayed at 0000. And last but not least is the digital guages above the vents. This also always tells me I only get about 11 miles to the gallon. And the digital fuel used meter always resets its self. How would I go around fixing some of these things?
  2. #2 Re: Fuel Guage not working
    Change the fuel sender on the fuel pump canister. That will likely fix the gauge and DIC.
    On the trip odo, that's a mechanical deal on your car correct?
  3. #3 Re: Fuel Guage not working
    Mar 2012
    Arkansas
    Yep. Its the same as a odometer just resetable. It doesn't roll as of two days ago. Probably need to have the whole cluster replaced soon though.
  4. #4 Re: Fuel Guage not working
    I'd hit up the junkyards/post for one about the right mileage and just swap it.
  5. #5 Re: Fuel Guage not working
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    as for your dash trip try pressing the button again sometimes i have to press mine a few times after i do the press and hold reset
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  6. #6 Re: Fuel Guage not working
    Regal...digital odo ftw.
  7. #7 Re: Fuel Guage not working
    Mar 2012
    Arkansas
    My odometer works, it was just my trip meter. My trip meter did begin to work. Im taking my car by the local Buick GMC dealership to have some work done on it. Ill ask around to see if they can find the problem with it. Get a estimate to decide if I should let them do the work or just do it myself. Im not an experienced technician when it comes to parts. Most I can do is change speakers and the radio. But I'm still living at home and my dad is very good with cars. Worked in a ford factory back in the 70s before everything got machine made. We are changing the struts and springs this week. Tires and breaks soon. Then everything else.
  8. #8 Re: Fuel Guage not working
    Dealer is likely going to tell you that a new fuel pump assembly (including sender) is needed at abotu $300. The sender which you can swap easier than any strut or radio costs about $30
    The odo tripper, they'll probably suggest a new or rebuilt cluster....again big moola
  9. #9 Re: Fuel Guage not working
    Mar 2012
    Arkansas
    That makes alot of sense. But I am worried that it might be more than just the sender.
  10. #10 Re: Fuel Guage not working
    I would give it a 99% chance of it being a sender. They are extremely common on the 97+ GM vehicles. If you look at a sender, there's 4-6 little fingers that ride a resistor slide. Over time the fingers break off. When this happens the sender only works in a couple of positions at best.
    If you wanted to test it..you could pull the pump assembly (15 min) and take a look at it.
  1. Gas Guage Not Working...Code P1441
    By 97GTzbban1 in forum General Tech Discussion
    Last Post: 08-08-2010, 04:37 AM
  2. 04 GTP Temp Guage Quit Working
    By trick94cobra in forum 04+ Specifics
    Last Post: 11-11-2009, 09:07 PM
  3. Please help fuel guage and gas spillage.
    By shadowcat11 in forum General Tech Discussion
    Last Post: 06-17-2009, 12:18 PM
  4. Fuel pressure guage question?
    By basshead42 in forum General Tech Discussion
    Last Post: 03-27-2009, 12:36 AM
