Thread: Passenger wheel and wheel area hot and smeels of hot metal
Results 1 to 9 of 9
  1. #1 Passenger wheel and wheel area hot and smeels of hot metal
    Jun 2012
    St. Paul, Minnesota
    On my way home from work tonight I noticed that when I left off the gas to coast my car was slowing faster than usual. It would make a light squeaking noise occasionally, and there was some vibration in the steering wheel. When I got closer to home I started smelling a hot metal smell coming through the vents. When I got home and parked in the garage I got out and did a walk around, and the front passenger wheel well had a ton of heat coming out of it and the wheel itself was uncomfortably hot to the touch. The smell was also very strong in that area.
    Any ideas on what the cause of this might be? I'm thinking that perhaps the caliper froze up slightly compressed and is constantly rubbing the rotor, but would that cause the actual wheel to get that hot?
    Car is a 01 GTP. 115k. CV's were done just a few months ago with NAPA's.
    Thanks.
  2. #2 Re: Passenger wheel and wheel area hot and smeels of hot metal
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Frozen or sticky caliper?
    Sent from my Galaxy Note 3
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  3. #3 Re: Passenger wheel and wheel area hot and smeels of hot metal
    Jul 2010
    Detroit
    I think it would cause it to get that hot. I mean that's constant friction... pad on rotor
    Ryan
  4. #4 Re: Passenger wheel and wheel area hot and smeels of hot metal
    The Boss Iceman6669's Avatar
    Jun 2011
    I had a brake lock on in my old truck once. By the time I got home the rim had actually changed color and was smoking.
    2011 F-150 Yote powered
  5. #5 Re: Passenger wheel and wheel area hot and smeels of hot metal
    Jan 2009
    Tallahassee, FL
    Time to dig into the brakes it looks like
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  6. #6 Re: Passenger wheel and wheel area hot and smeels of hot metal
    Jun 2012
    St. Paul, Minnesota
    Awesome. I figured it was the brakes. Hopefully I didn't warp the rotor. Now all I have to do is limp it to work so I can work on it in the heated warehouse. Back roads and frequent stops. Yay. :/
  7. #7 Re: Passenger wheel and wheel area hot and smeels of hot metal
    i had a caliper stick on a old vw rabbit, the whole wheel was glowing red. i was waiting for the tire to blow out.
    same deal on my old 80 dodge plow truck, the wheel was glowing red. ended that night of plowing.
    the rotor was more then dead after both times.
  8. #8 Re: Passenger wheel and wheel area hot and smeels of hot metal
    Dec 2012
    troll land
    I worked on a 99 gp gt once that did the same thing, ended up bein a destroyed wheel bearing
  9. #9 Re: Passenger wheel and wheel area hot and smeels of hot metal
    St. Louis
    If you are going to replace the caliper on that side, then I would recommend that you replace BOTH front brake hoses while you're at it. If the hose is collapsing internally and not allow the fluid to return to the master then it will cause the caliper to stick. Went through this with my Bonneville. I think it was the hoses, which in turn caused the caliper to stick then the heat generated by the time I got home killed the caliper off and destroyed the rotor. And yes, it was smoking hot as well. So far the front hub seems to have survived but I know it took an awful lot of heat.
  1. Squeaky noise from front passenger wheel...
    By 06GXPGAL in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2013, 09:48 PM
  2. Front passenger wheel help
    By DirtDog in forum General Tech Discussion
    Last Post: 09-09-2012, 03:14 PM
  3. Metal scraping sound from front wheel
    By apok in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2012, 09:05 PM
  4. Strange Noise from Driver front wheel area
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2011, 05:36 PM
