Thread: trac off light and parking break on
Results 1 to 6 of 6
  1. #1 trac off light and parking break on
    Apr 2012
    Huntington, WV
    I just bought my grand prix and am having a peculiar issue. When I hit the accelerator my traction control turns off and my parking brake light comes on. Usually when I hit the break it goes off, but not always. The abs light is not on. I have checked the brake fluid in the master cyl. I am new to the site and any help is appreciated.
  2. #2 Re: trac off light and parking break on
    Apr 2009
    Fort Worth TX
    Make, model (SE-GT-GTP-GXP), year?...so we can help out.
  3. #3 Re: trac off light and parking break on
    Pennsylvania
    I will recommend getting it scanned with a Tech II to see what codes it's throwing.
  4. #4 Re: trac off light and parking break on
    Apr 2012
    Huntington, WV
    It is a bit of a toss up. Its a 97 SE i believe. Although the vin starts with a 1, which is usually reserved for the gtp. But I have no s/c.
  5. #5 Re: trac off light and parking break on
    It's not the starting number that tells the motor it's the 8th i believe.
  6. #6 Re: trac off light and parking break on
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    yes the first number tell you the country it was built in, 8th is engine and 10th is year
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  1. Trac OFF + Parking Brake Light on while accelerating
    By EJOUIE in forum General Tech Discussion
    Last Post: 03-06-2012, 12:05 AM
  2. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  3. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  4. break light
    By 1LoudGrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 09-08-2009, 04:09 PM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
