Thread: Alternator Voltage Booster - Pros and Cons
Results 1 to 9 of 9
  1. #1 Alternator Voltage Booster - Pros and Cons
    Because Wet Leaves Hippo Machine's Avatar
    Jun 2011
    Detroit, MI
    I was considering the Voltage booster made by Easy Performance for our cars and was wondering what the repurcussions were for installing it?
    I have a aftermarket speakers, headunit, sub, and soon to have 5-channel amp. Will this damage any of my electronics?
    Please let me know the pros and cons!!
    Thankies
    iLoveSpade
  2. #2 Re: Alternator Voltage Booster - Pros and Cons
    Jan 2012
    Philadelphia
    just curious why would you want to boost your voltage?
  3. #3 Re: Alternator Voltage Booster - Pros and Cons
    Charles City, IA
    Theres really no point for it.
    SMGPFC Two Nipple General
  4. #4 Re: Alternator Voltage Booster - Pros and Cons
    Jun 2011
    Detroit, MI
    I have a lot of aftermarket speakers and stuff that take power quick, thought it would help charge my batt faster. Also my windows are very slow, don't know if it would help that. AND my rear defrost is really slow lol. AND headlights are pretty dim.
    iLoveSpade
  5. #5 Re: Alternator Voltage Booster - Pros and Cons
    Charles City, IA
    you need more amperage not voltage.
  6. #6 Re: Alternator Voltage Booster - Pros and Cons
    big 3,
    Bigger Wires
    Bigger Alt
    and, well i forgot the 3rd but you know
    SMGPFC Member #10
  7. #7 Re: Alternator Voltage Booster - Pros and Cons
    Jun 2011
    Detroit, MI
    I'm just gonna go with the big 3 upgrade and alt rewire then eventually.
    iLoveSpade
  8. #8 Re: Alternator Voltage Booster - Pros and Cons
    Dec 2008
    Lawndale, CA
    I can't remember if you are using HIDs or not. Either way I recommend you use a relay harness to not have them dim.
  9. #9 Re: Alternator Voltage Booster - Pros and Cons
    Is that the simple...brings it to 15 volts booster or the same as the caspers that ups the volts over 70% throttle?
  1. zzp pcm pros and cons
    By BlackGT97 in forum General Tech Discussion
    Last Post: 09-21-2011, 03:45 PM
  2. Pros and cons of GTP??
    By up in boost in forum Off Topic Discussion
    Last Post: 01-14-2010, 02:23 PM
  3. pros and cons
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 11:19 PM
  4. Alternator Voltage Booster question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2009, 07:23 AM
  5. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
