Thread: fuel vapor smell....
Results 1 to 4 of 4
  1. #1 fuel vapor smell....
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    for the past few weeks I'll get a strong whiff of fuel vapor on occasion after I shut my car off. It's not a raw fuel smell and it doesn't always happen --- but when it does the smell is very strong. the first time I noticed it I immediately checked the fuel connects at the engine and checked out the lines to the tank and didn't / don't see any fuel leaks. I got under the back a week or so ago and other than the rusted lines (that should be probably replaced) everything looked okay. It seems like right after a fill up and during hot days it's the worst.
    Anyway, I smelled it today after I parked in the garage and popped the gas cap to see if there was pressure built up ---- there wasn't but what I heard was a bubbling sound, like high pressure air was being blown into the tank. It would "glub" a couple of times then wait a second or two and then repeat. It didn't seem like the strong fuel smell was coming from the tank --- but damn I can't pinpoint it either.
    I replaced the solenoid within the past few years but don't know the evap system as well as I probably should so I'm not sure where to start looking. So if you can make heads or tails of this message I'd appreciate any ideas where to start looking.
    thanks!
  2. #2 Re: fuel vapor smell....
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    possibly have something to do with your spark plugs or even your exhaust/cat conv. ... maybe some un-burnt fuel is what your smelling? then again it might be alil more complex?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #3 Re: fuel vapor smell....
    Feb 2008
    I'm interested in what this is too, I also sometimes have that smell coming from mine.
  4. #4 Re: fuel vapor smell....
    Jul 2008
    sumter,south carolina
    check the O ring on your fuel pump...it could b dry rotted...the reason i say this is because it happened to me.its accesible through the trunk...pull back carpet youll see a little plate that has a handful of screws open that and check there.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Air condition/vents smell when turned on! How do I fix?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-08-2008, 12:54 PM
  4. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
