Thread: downshifts 2 gears then SES for 5-10 seconds
Results 1 to 5 of 5
  1. #1 downshifts 2 gears then SES for 5-10 seconds
    Mar 2012
    ohio
    it is a 95 gtp + perfomace package so it has the (what should be) 200 HP 3.4L DOHC V6. lately it has been downshifting 2 gears then SES light comes on for 5-10 seconds. We took the car to autozone today for a ECM scan but they told us they couldn't do it because its a 95 and the SES light isnt on. On the way home it downshifts 2 gears then the SES light comes on, when it turned off BAM, FACE TO DASH then of course..........SES.
    Also the throttle body has warped in time so the peddle sticks both ways, often and very stiff, when it gets stuck open the transmission goes into whatever gear it wants(within reason) often with absolutely no throttle movement. This has been happening since we bought the car
    I think that a few of problems are caused by the ECM but im not quite an expert, if you could give me some advice i would appreciate it cause i dont much want to drive the car if its trying to kill its occupants.
  2. #2 Re: downshifts 2 gears then SES for 5-10 seconds
    Apr 2009
    Fort Worth TX
    Not driving the car because it down shifts is irrelevant when the throttle body is sticking (very dangerous).
    Clean/repair the throttle body.
    See if it does this 2 gear thing when the shifter is in manual.
  3. #3 Re: downshifts 2 gears then SES for 5-10 seconds
    ^^ I'm with stupid
  4. #4 Re: downshifts 2 gears then SES for 5-10 seconds
    Mar 2012
    ohio
    throttle body has been cleaned and even lubed many times. works fine for about a half hour then goes back to start
  5. #5 Re: downshifts 2 gears then SES for 5-10 seconds
    Apr 2009
    Fort Worth TX
    Where is the nearest junk yard to you. Take the car along with the title and get your $50. JK
    Yea, go to the yard and see if you can locate a TB. It'll be cheap, probably $20 or something.
  1. 91 Grand Prix 3.1L hard upshifts / downshifts
    By neorules in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-18-2011, 09:09 AM
  2. No gears after a few seconds of running
    By Biohazed in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-28-2011, 08:10 PM
  3. Car kills out after a few seconds
    By Kissner in forum General Tech Discussion
    Last Post: 03-16-2010, 07:32 PM
  4. 4-1 and 3-1 downshifts
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2010, 07:46 PM
  5. Please take 2 seconds and vote for us to get a strip
    By Z28 in forum Off Topic Discussion
    Last Post: 07-27-2009, 06:19 PM
