Thread: car wont stay running
Results 1 to 7 of 7
  1. #1 car wont stay running
    Aug 2008
    trinity, fl
    i am having problems with my car if anyone has an idea please let me know. it was running fine at lunch but when i went to leave work it wouldnt stay running. it will start just fine and run for a couple of seconds and then die. i replaced the fuel filter but didnt solve the problem. doesnt hold pressure on the fuel rail. starts at 40 psi and once the car is running it goes down to nothing. hasnt givin me any codes yet. it is a 98 gtp. if anyone has an idea please pm me and let me know. thanks
  2. #2 Re: car wont stay running
    Banned
    Wichita Falls, Texas
    Your going to need to post much more information than that, or no one can help you.
    As of right now, given the information you've provided. I'd say you blew your motor up.
  3. #3 Re: car wont stay running
    Aug 2008
    trinity, fl
    and wher did you get your information?
  4. #4 Re: car wont stay running
    Banned
    Certainly not from you.
    Like I stated before, why don't you actually tell us what it's doing?
  5. #5 Re: car wont stay running
    Banned
    Ah, seeing as you've now edited your original post to include more information on whats going on, heres what you need to do.
    Your problem is more than likely your fuel pump resistor.
    Go to the fuse box under your hood, open it and bend the tab in the picture above. It puts your fuel pump in high mode and will fix your problem if thats the case.
  6. #6 Re: car wont stay running
    Aug 2008
    trinity, fl
    thanks. ill give it shot once i get to work in the morning.
  7. #7 Re: car wont stay running
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    FINALLY, ive been searching for 20 minutes on how to do the fuel pump resistor mod, and finally found it!
    so if this mod fixes my problem, does that mean the resistor is bad, or the pump is failing??? if its the resistor, how much do those cost, on average?
    edit: crap, just realized the pic says for 97-00..... guess ill go give it a looksie anyways...
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  1. Car died in traffic, won't stay running.
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 10:28 PM
  2. Stay away from street races!
    By Sabrewings in forum Off Topic Discussion
    Last Post: 09-07-2008, 10:44 PM
  3. Car will not stay running
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 07:30 AM
  4. Stay alert peeps! (eastern KS Western MO)
    By Reptile in forum Off Topic Discussion
    Last Post: 05-03-2008, 09:47 AM
  5. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
