Thread: nitrous/pcm
Results 1 to 9 of 9
  1. #1 nitrous/pcm
    Jul 2008
    Poteau Oklahoma
    a few years ago I saw an ad about a camaro. they had put a huge nitrous nozel right behind the air filter and said that the pcm would take care of the fuel curve. my question is. Is this what everyone is using now? if not has anyone tried it? Is it an efficent way of juicing up these rides? Is it even cost effective? Or do you have to have a programer to use this stuff?
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  2. #2 Re: nitrous/pcm
    Apr 2008
    Chillin at the Beach , VA
    I seen a show on that. An old Horsepower TV. They added nos to a camaro and said the same thing. That the pcm would compensate for the change. They ran it on the dyno and got the gains they wanted.
  3. #3 Re: nitrous/pcm
    Jul 2008
    Poteau Oklahoma
    anybody else?
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  4. #4 Re: nitrous/pcm
    Banned
    Wichita Falls, Texas
    I wouldn't trust that set up.
  5. #5 Re: nitrous/pcm
    Moore,OK
    Quote Originally Posted by Street Wolf View Post
    X2
    it MIGHT make up for a 25 shot but anything bigger than that you're gonna have to supplement the fuel side.
    hijack on
    is anybody running a 65 or bigger shot? what kinda setup are you running and do you like it?
    hijack off
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  6. #6 Re: nitrous/pcm
    Banned
    Quote Originally Posted by whiteknuckle View Post
    X2
    hijack on
    hijack off
    I run a 75 shot, custom set-up between NX, and NOS brand. Love it too, can't beat the gains you get out of it for the money you spend to purchase it.
  7. #7 Re: nitrous/pcm
    Wichita, KS
    Pretty much they are spraying the nitrous across the MAF sensor. Cold air temperature is read, the PCM then fattens up the fuel mix, which in theory gives you the additional fuel you need.
    For our cars, spraying cold nitrous across a HEATED MAF sensor = premature death to the sensor. If you have ever had a problem with a failing or bad MAF you can understand how problematic it can be to determine thats whats wrong with your car.
    For me and my old set up, I was injecting my nitrous after the throttle body, and before the supercharger. It could handle a 75 shot no problem what so ever.
    My next new current set up is direct port, via a custom made nitrous spacer plate that sits UNDER the supercharger and sprays nitrous directly into each intake runner evenly.
    Problem with spraying through the supercharger, and the ONLY problem is getting true even, port mixture/cylinder mixture. The way the out let of the supercharger is designed, and the direction of the rotors and how they spin, loads up one or two more cylinders with a much greater hit of nitrous than the others.
    Nitrous does not have any effects on the rotor coating, wet or dry system. The coating only peals off, if the rotors were coated incorrectly from Eaton to begin with. Same thing with running alcohol injection, no effect on rotor coating being harmed.
    ~F~
  8. #8 Re: nitrous/pcm
    Jul 2008
    Poteau Oklahoma
    good info GR8. thanks. and to this date I havet had to replace ANY of the sensors on either of my gp. knock knock
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  9. #9 Re: nitrous/pcm
    I live here. UR LOSN's Avatar
    Rockford, IL
    bunch of Camaro/ TA's have an open line under the air filter in the lid. they just open line it. you do pick up some......
    the computer corrects for it, because it has to go through the MAf sensor....
  1. Nitrous (ZEX)
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2008, 12:19 PM
  2. Nitrous oxide anyone?
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 04:39 AM
  3. Another Nitrous Question... Dry vs. Wet
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-28-2008, 03:37 AM
