Ok I found a GTP in the junk yard, it was wrecked from behind. Im getting the whole engine and transmission cheap because we know the owners well. My questions are what exactly do i need to pull off the old engine to make this work the best. The super charger, LIM, Fuel rail, for sure. But now what? Can I use the GTP stock fuel injectors or do I need to buy different ones? Can the stock PCM work for it or do I have to get it re-programmed? Should I use the GTP stock Rockers? In the future I want to put a cam in it so ill need new springs and re-tuned PCM for that. Anything else I should take? Also what is a Built transmission? Can I tear apart this extra one I have and add parts to it? Thanks for the Help
