Thread: 07 prix main ground wires, where at??
Results 1 to 7 of 7
  1. #1 07 prix main ground wires, where at??
    May 2011
    wisconsin
    I want to upgrade my grounds in my car so I can get rid of this annoying ground loop. Where are the main grounds at? Besides the battery to chassis. I heard there are for of them. Detailed description or pictures would be a huge boner for this one, thanks guys!
  2. #2 Re: 07 prix main ground wires, where at??
    Pennsylvania
    Quote Originally Posted by szalajka05 View Post
    wut
  3. #3 Re: 07 prix main ground wires, where at??
    You talking interior or exterior with that big boner?
    Should be a ground pack usually in each corner of the car.
  4. #4 Re: 07 prix main ground wires, where at??
    May 2011
    wisconsin
    Quote Originally Posted by SlowNA06 View Post
    wut
    Lol! huge boner is a metaphor for overly excited for the help. I heard that there is main grounds at...
    Battery to chassis
    Trans to chassis
    Engine to chassis
    Engine to trans??
  5. #5 Re: 07 prix main ground wires, where at??
    May 2011
    wisconsin
  6. #6 Re: 07 prix main ground wires, where at??
    Apr 2009
    Fort Worth TX
    Most of the noise is coming from the ignition system on the engine. The main ground is on a transmission bolt/stud (15mm) right above the starter. If the noise is clipped at the engine then you don't have to worry about all of the other grounds in the car. You may be able to run some cables right from the battery(-) to the engine block and chassi. Some ferrite noise suppressors on the large grounds may block out some annoying EMI but these are generally for higher frequency. Couple this with some filters on the equipment supplies and you'll be quiet as a church mouse.
    Upgrading grounds does not get rid of noise, filters and suppressors do. Remember, a car is a giant floating ground system, unless you want to drag a cable on the ground will you're driving.
    I hope this helps.
  7. #7 Re: 07 prix main ground wires, where at??
    May 2011
    wisconsin
    Will I have ten feet of zero gauge wire left so I think im just going to find all the grounds and replace them. Or I could just drag some wires behind me like you say lol
  1. Put a 2001 engine in a 1998 grand prix..help!!! Wires smoking
    By Djstanley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2012, 01:46 PM
  2. Request for a picture of your bellhousing ground wires....
    By copgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2012, 04:04 PM
  3. main caps
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2011, 01:11 AM
  4. main cap and rod bolts
    By chev1988rolet in forum Off Topic Discussion
    Last Post: 07-30-2010, 01:46 AM
  5. Bad main bearing?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 11:05 AM
