Thread: ABS Wheel Sensor Harness, HELP
Results 1 to 9 of 9
  1. #1 ABS Wheel Sensor Harness, HELP
    Donating Users foursixer's Avatar
    boston,ma
    do anyone know if the abs wheels sensor harness from dorman #970-043 work on a 98 gtp? my sensor harness can be unpluged from just around the water pump. the dorman 970-042 has to be spliced in. other the dealership, where can i purchased this harness (plug and play)?
    Amazon.com: Dorman 970-043 ABS Speed Sensor: Automotive
    Amazon.com: Dorman 970-042 ABS Sensor with Harness: Automotive
    Amazon.com: Dorman 970-040 ABS Sensor with Harness: Automotive
    Other Peoples Reject....The Red Ripper!
  2. #2 Re: ABS Wheel Sensor Harness, HELP
    Grand Rapids, MI
    I believe yours is plug and play so you would need 043. Mine was wired all the way into the main harness and thus had to be spliced in.
    Just follow it up and double check what kind you have.
  3. #3 Re: ABS Wheel Sensor Harness, HELP
    boston,ma
    ^yes, mine is definitely plug and play! dorman stated that they dont fit the grand prix, but they certainly look like the harness on my 98 gtp. i dont want to buy them and have to ship it back. would they work for the left and right side?
  4. #4 Re: ABS Wheel Sensor Harness, HELP
    Grand Rapids, MI
    i believe so... but that's just glancing at em. there's two types and you found them.
  5. #5 Re: ABS Wheel Sensor Harness, HELP
    boston,ma
    the picture of the 970-043 is not great! i tried searching and could not find anyone that used them on a gtp. everyone makes reference to the 970-042, the splice harness. i dont want to go this route.
  6. #6 Re: ABS Wheel Sensor Harness, HELP
    Grand Rapids, MI
    well just get out there and look at your car, trace the harness and see if it unplugs or if it will need to be spliced. And if splicing is what makes you nervous, then order some posi-locks. They are easy to use and the equivalent of soldering (which I never can get right lol)
  7. #7 Re: ABS Wheel Sensor Harness, HELP
    Mar 2012
    Michigan
    plug
  8. #8 Re: ABS Wheel Sensor Harness, HELP
    boston,ma
    Quote Originally Posted by brandonl2000 View Post
    probably am not clear, like i said mine is definitely PLUGS! IT CAN BE DISCONNECTED AT THE WATER PUMP AREA. my question is, i need to know if anyone else have used the 970-043 harness? dorman states that it DONT fit the grand prix according to there vehicle fitment guide. can anyone verify if this 970-043 fits, if not where can i get the harness that do fit, other than going to the junkyard or dealership.
  9. #9 Re: ABS Wheel Sensor Harness, HELP
    boston,ma
    the 970-044 do not work. i removed all the wheel harnesses front and rear (yes the rear can also be discounted were the trailing arm mount to the frame). i used an ohm meter to check resistance or wire breakage. all the harnesses gave the same resistance. i put dielectric grease on them and reinstall. its been two weeeks and the light yet to return. it seems like the grease fixed the problem.
  1. steering wheel control harness
    By Stragler in forum Audio, Security & Visual Electronics
    Last Post: 05-26-2011, 02:34 PM
  2. Harness for coolant temperature sensor
    By Duffman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:13 PM
  3. Wheel Speed Sensor Wireing harness
    By packerfanjc in forum Tires & Wheels
    Last Post: 02-16-2011, 10:09 AM
  4. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  5. input speed sensor wheel, do i need a new one when swapping gears?
    By Merlin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2009, 09:48 PM
