Thread: Crazy KR
Results 1 to 20 of 21
  1. #1 Crazy KR
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Hi Guys, I received my aeroforce scangauge and I went for a little drive... I gunned it and saw up 6 KR at arround 5000 RPM... I did TWO runs 0-150 KM/H, I popped the hood and my manifold was glowing red...
    I have a ZZP 3'' DP with a Highflow CAT,Air intake, Autolite 606's, 180 tstat, Borla 2.5'' catback, Stock pulley. and im running 91 octane gaz..
    Im looking into headers now,
    What could be the problem?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  2. #2 Re: Crazy KR
    Clogged up exhaust.
  3. #3 Re: Crazy KR
    Jul 2010
    Montreal
    could it be my cat? I installed the catback yesterday, My front manifold was glowing red last week with my stock exhaust after 2 runs...
    Dec 2010
    DMV
    Quote Originally Posted by biggt View Post
    Sounds like a cat to me
  5. #5 Re: Crazy KR
    Pennsylvania
    How many miles on the cat? I doubt that it's toast. Doubt it would take much to cherry stock manifolds. I might try AL605's and scan again.
  6. #6 Re: Crazy KR
    Jul 2010
    Montreal
    the cat has maybe 15 000km...
  7. #7 Re: Crazy KR
    Out West
    combination of NO timing (stock condition), and a merciless beating.
    Whine with your Cheese?
  8. #8 Re: Crazy KR
    Apr 2009
    Fort Worth TX
    Is your car a GTP or a GT top swap? Sorry if this is a stupid question..your user name suggest that it is a GT.
  9. #9 Re: Crazy KR
    Glowing manifolds are from heat. It can be from a lean condition or back pressure, most commonly.
  10. #10 Re: Crazy KR
    Pennsylvania
    Quote Originally Posted by Rico View Post
    It's an L67.
  11. #11 Re: Crazy KR
    Jul 2010
    Montreal
    I dont think my cat is clogged because when i swapped my exhaust line i started the car Open DP and i had good pressure coming out...
    So all stock GTP will glow red?
    and what could cause a lean condition or back pressure? (im french so i migh not express myself properly lol...)
  12. #12 Re: Crazy KR
    Pennsylvania
    Lean condition means there is too much air for proper combustion. So... bad or dirty MAF, vacuum leak, tiny pulley, etc.
    Back pressure is caused by exhaust restrictions, of which you really have none.
  13. #13 Re: Crazy KR
    Just because the cat was good then, doesn't mean it isn't now.
  14. #14 Re: Crazy KR
    Feb 2009
    flintnasty MI
    Glowing manifolds result from running 10 degrees of timing as well... so if you are still laying into things at 10 degrees it will get pretty warm.
  15. #15 Re: Crazy KR
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    Quote Originally Posted by SlowNA06 View Post
    I noticed when I am going up any sort of incline to i get almost 5 or 6 degrees the longer the hill
  16. #16 Re: Crazy KR
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Quote Originally Posted by SoergBot View Post
    Engine load goes up because TC is locked. Either need to tune the trans for a downshift, tune for less timing vs MAP, or run higher octane fuel.
  17. #17 Re: Crazy KR
  18. #18 Re: Crazy KR
    Balancer could be toast as well.
    Ala, glowing exhaust from skewed timing via the balancer being off.
  19. #19 Re: Crazy KR
    Apr 2009
    Fort Worth TX
    Ah, wideband?
  20. #20 Re: Crazy KR
    Jul 2010
    Montreal
    so my best bet would be to do headers and get a tune?
  1. Help me my car is going crazy!!
    By csssaint12 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2011, 12:53 PM
  2. This is crazy
    By Ricky21 in forum Off Topic Discussion
    Last Post: 09-21-2010, 08:10 PM
  3. This is crazy
    By 40mphGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 07:32 PM
  4. crazy car need some help
    By KingOfTheSouth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2009, 12:29 AM
  5. crazy but possible......
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-16-2008, 08:42 PM
