Thread: compatible steering racks for grand prix
Results 1 to 12 of 12
  1. #1 compatible steering racks for grand prix
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i was thinking about putting a new steering rack to tighten up the steering but i want to know what racks are bolt on compatible? for 97-03 grand prix
  2. #2 Re: compatible steering racks for grand prix
    St. Louis
    Um, a rack for your specific year??? Not sure what else crosses with it as manufacturers have a nasty habit of making mid year changes to things or even using different fittings/locations on other cars in the same platform.
    Best to stick w/ a true reman. Delco rack. Then you just have to figure out if you have Magnasteer or not.
  3. #3 Re: compatible steering racks for grand prix
    HUDSON
    Dont pay more for the Delco reman. rack. They (Delco) get thiers from the same suppliers as everbody else, I learned this when searching for a rack for my car.
  4. #4 Re: compatible steering racks for grand prix
    Oct 2011
    Michigan
    these cars have such lose steering though i need tighter steering
  5. #5 Re: compatible steering racks for grand prix
    replace the tie rods and other suspension parts and your steering will get much better
  6. #6 Re: compatible steering racks for grand prix
    SWPA
    Its not a sports car. The steering is what it is.
  7. #7 Re: compatible steering racks for grand prix
    Oct 2011
    Michigan
    it is a sports car and i alright have replaced the front suspension
  8. #8 Re: compatible steering racks for grand prix
    Everything on the front suspension? Shocks and struts would probably help a lot. Your probably getting loose steering confused with body roll. My cars steering is pretty tight.
  9. #9 Re: compatible steering racks for grand prix
    SWPA
    Quote Originally Posted by asite57 View Post
    Do you even know what a sports car is? Because a Grand Prix is NOT one. Its a family car.
  10. #10 Re: compatible steering racks for grand prix
    Oct 2011
    Michigan
    its an exciting daily driver and most definitely a sports car
  11. #11 Re: compatible steering racks for grand prix
    Minnesota
    Way to contribute.
    To the OP:
    If you feel like you have excessive slop in the steering wheel you could replace the tie rods and/or try and tighten the tie rod end.
    Back the jam nut off the tie rod end and screw them on a little more. Suspension wise, just make sure everything else is tight and not worn out. That includes the lower and upper mounts and the ball joints.
  12. #12 Re: compatible steering racks for grand prix
    SWPA
    No its not a sports car, its a front heavy, FWD family car. The steering is what it is. If you have replaced anything that can have slop, then that is what you have.
  1. Crunch in steering wheel '04 Grand Prix
    By Paul in WV in forum Brakes/Suspension/Chassis
    Last Post: 11-02-2011, 11:21 PM
  2. 2006 pontiac grand prix steering issue
    By AZAALGMONLY in forum General Tech Discussion
    Last Post: 04-01-2011, 09:50 AM
  3. 1990 grand prix power steering?
    By barrylincon in forum General Tech Discussion
    Last Post: 09-03-2010, 06:05 PM
  4. 1999 Grand Prix 3.1L steering problem
    By Big Tom in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2008, 11:05 AM
