i was thinking about putting a new steering rack to tighten up the steering but i want to know what racks are bolt on compatible? for 97-03 grand prix
Um, a rack for your specific year??? Not sure what else crosses with it as manufacturers have a nasty habit of making mid year changes to things or even using different fittings/locations on other cars in the same platform.
Best to stick w/ a true reman. Delco rack. Then you just have to figure out if you have Magnasteer or not.
replace the tie rods and other suspension parts and your steering will get much better
Everything on the front suspension? Shocks and struts would probably help a lot. Your probably getting loose steering confused with body roll. My cars steering is pretty tight.
Way to contribute.
To the OP:
If you feel like you have excessive slop in the steering wheel you could replace the tie rods and/or try and tighten the tie rod end.
Back the jam nut off the tie rod end and screw them on a little more. Suspension wise, just make sure everything else is tight and not worn out. That includes the lower and upper mounts and the ball joints.
