Thread: Fuel enable circuit 229-Polarity
Results 1 to 2 of 2
  1. #1 Fuel enable circuit 229-Polarity
    May 2011
    Bremen,GA
    Hey guys,I,m wanting to switch out the pcm on my 97 GT,I have an extra 97 pcm from a regal that has the same service numbers.
    The problem is that the buick pcm has the security enabled and my gt has no factory security.
    Does anyone know what the polarity is on pin 70 in blue harness when fuel is enabled?
  2. #2 Re: Fuel enable circuit 229-Polarity
    While I don't have your answer, typically the pcm uses ground to control relays.
  1. Fuel pump circuit power draw car dies in 4 days
    By 67eftw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2012, 09:55 AM
  2. P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    By WonBadGTP in forum General Tech Discussion
    Last Post: 02-14-2011, 08:41 AM
  3. Code: theft deterrent fuel enable
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2010, 04:01 PM
  4. p0230 fuel pump relay circuit
    By Golgo13 in forum General Tech Discussion
    Last Post: 02-27-2009, 10:31 AM
  5. underhood relay center/ voltage to fuel circuit
    Last Post: 02-06-2009, 05:10 PM
