Thread: speed daddy
Results 1 to 10 of 10
  1. #1 speed daddy
    antioch ill
    so I heard from several people to get some speed daddy headers for my 00 gtp so i went to ebay to look at some of their stuff and it seems way to good to be true becuase it is so cheap im wondering if the stuff is legit not some knock off chinese crap. Reveiws?
  3. #3 Re: speed daddy
    Donating Users lflylow's Avatar
    Yakima, WA
    I have them, installed no problems, search for the forums there is a thread that lists everything you need to install um.
    2000 GTP, retro's, Debadged, 15% Tint, SD headers, TB HAI, EGR delete,
    Tuned By Reptile, WBS Perf. LCA's, GMPP rear sway bar Dorman front, Tinted tails.
  4. #4 Re: speed daddy
    flex leaks.
    primaries dont line up with heads.
    Crossover holes can be perfect or oblong.
    Crossover might have to be trimmed.
    Goose neck is an issue if you're lowered.
  5. #5 Re: speed daddy
    GT Level Member ShadowSwept's Avatar
    Kentucky
    I should perhaps type faster :P
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  6. #6 Re: speed daddy
    antioch ill
    I also noticed a lot of their products are really cheap has anyone bought anything else from them?
  7. #7 Re: speed daddy
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    6 year old speed daddy/SSAC's still in good shape
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: speed daddy
    Had mine for almost a year.
    No problems at all.
    I repalced the the flex pipe before I installed to not deal with the first one leaking. All of it bolted up fine and sealed good, only had to trim 1/4in off one end of the crossover to make it slide in easy.
  9. #9 Re: speed daddy
    antioch ill
    if i put on aftermarket headers and gets rid of my cat how do i pass emissions?
  10. #10 Re: speed daddy
    If your state has emission, you buy an aftermarket cat that goes inplace of the "race pipe" on the headers downpipe section.
  1. speed daddy s/c or not
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2011, 07:47 PM
  2. speed daddy 04+
    By donkason in forum General Tech Discussion
    Last Post: 04-26-2011, 02:24 PM
  3. speed daddy's
    By Feminist turnip in forum 04+ Specifics
    Last Post: 02-02-2011, 08:53 AM
