Thread: Tranny Fluid - To change or not to change.
Results 1 to 8 of 8
  1. #1 Tranny Fluid - To change or not to change.
    SE Level Member midrange's Avatar
    Belleville, Ontario
    So in the past I was told never to change the tranny fluid if the vehicle had high millage and the tranny fluid wasn't changed before.
    Reasons being it could cause more problems than good if you did.
    I also read in a recent post on this site that you shouldn't if it wasn't maintained before. It started making me wonder if I should change mine or not. Right now, my tranny fluid is not new looking (bit dirty, still somewhat clear red looking), but its also not super dirty brown.
    It worries me that if I did change it, I could be creating more problems.
    Whats everyones thought on this? 04 with 241000k. (kms, not miles) Shifts pretty smooth under slow acceloration, but you can feel it change gears under a heavier load and acceloration.
    2004 Grand Prix GT1
  2. #2 Re: Tranny Fluid - To change or not to change.
    Just drop the pan a do a filter change you won't hurt anything.
  3. #3 Re: Tranny Fluid - To change or not to change.
    Pennsylvania
    Quote Originally Posted by midrange View Post
    If it's broke, it's broke. Might squeeze a few more thousand miles out with a fluid change, but I'd rather save it for the new transmission.
  4. #4 Re: Tranny Fluid - To change or not to change.
    I would do it. I did mine at 161,000 miles which should put that slightly above what you have. Use regular cheap dex 3 and add a container of lucas no slip or lubeguard with it.
  5. #5 Re: Tranny Fluid - To change or not to change.
    Belleville, Ontario
    Alright, thanks Bill. I'll give it a shot.
    SlowNA06 - I don't really think its broken, its just shifting a little harder than it should.. Perhaps fresh dex will help.
    2004 Grand Prix GT1
  6. #6 Re: Tranny Fluid - To change or not to change.
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    Dude ... If you have to ever change your tranny , any 04 up will work just use your original differential from your tranny should work fine, or rebuild yours. I'm going threw that now w/ my 04, good luck!! Oh and don't forget the lucas !!!
    04 GT1
  7. #7 Re: Tranny Fluid - To change or not to change.
    PA
    I would do the pan drop and filter change as well. Can't hurt it.
    2001 GSE
  8. #8 Re: Tranny Fluid - To change or not to change.
    Jan 2012
    CULPEPER VA.
    I rec. Replace filter and gasket then do a bg fluid exchange. Btw if you perform a bg trans fluid exchange befor 75k bg will at no charge warranty the trans for life if you perform the service every 30k. My wife has 186k on hers and shifts nike new thanks to regular bg fluid exchanges. If the trans ever fails we has $2000. Worth of coverage on it. I dont work for bg but its the best product out there and you cant buy a warranty like that. You get a free unlimited time and mileage warranty for doing what you should be doing anyway.
  1. 01 gtp Trans fluid change
    By Draco in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2011, 07:38 PM
  2. looking to change tranny fluid
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2011, 05:48 PM
  3. Dex VI Fluid Change
    By The Guz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2010, 04:55 PM
  4. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
  5. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
