Thread: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
Results 1 to 13 of 13
  1. #1 Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    SE Level Member WaterBoy's Avatar
    Jan 2012
    Canada
    I pulled the cluster on my 03 GTP today to replace what I thought would be a couple blown bulbs on left side of the cluster but… When I put the new ones in they wouldn’t work… I then swapped them with the right side working bulbs and still a no go??? What could it be?
    03 Grand Prix GTP Sedan (Silver)
  2. #2 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Jan 2012
    Canada
    Come on guys! 50 views, someone must have an idea???
  3. #3 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Im having the same problem, glad to see im not the only one. SOMEONE PLEASE ANSWER THIS!!!!
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  4. #4 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i dont have a clue but since so many ppl have viewed and no one helped i'll offer suggestions. are you sure you have power going to those light sockets?
  5. #5 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Jan 2012
    Canada
    Quote Originally Posted by bps02gtp View Post
    No I'm not sure if there's power there or not. I was kind of in a rush last night and didn't have time to dig out my light tester.
  6. #6 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    SE Level Member midrange's Avatar
    Belleville, Ontario
    Pull the cluster again.. Pull the circuite board out and look at all solder points. Check for non clean points (dry solder points).. If you see bad ones, heat with soldeirng iron, add fresh solder and test.
  7. #7 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Jan 2012
    Canada
    Quote Originally Posted by midrange View Post
    Will Do, thanks! Any tip or pointers on removing the circuit board?
  8. #8 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Belleville, Ontario
    once you pull the cluster.. there should be tabes holding it together.. perhaps some screws.. take it slowly and it will easliy come apart once cluster is out.
    2004 Grand Prix GT1
  9. #9 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    And...while you are at it.. follow the circuit to look for any breaks in the loop.
  10. #10 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Jan 2012
    Canada
    Will do guys! Thanks for the help! I'll let you know how I make out.
  11. #11 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Houston
    The circuit board? Its not like the DIC where its a hard plactic piece with soldering points. The instrument cluster is a flexible piece with foil tracers and no soldering points.
  12. #12 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Belleville, Ontario
    i've personaly never pulled out a GP board, but I have pulled out many clusters due to something not working and most had an issue with soldering points.. If there is no points, look for breaks.
    2004 Grand Prix GT1
  13. #13 Re: Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    Yoga city
    if not just wire in your own lights
  1. Getting half boost at the gauge.
    By falcz420 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:56 PM
  2. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  3. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  4. Dash Gauge Lighting
    By Rhino515 in forum Audio, Security & Visual Electronics
    Last Post: 12-01-2010, 11:44 AM
  5. Where Can I Find Good Gauge Cluster Schematics?
    By Logan in forum General Tech Discussion
    Last Post: 09-10-2010, 09:50 PM
