Thread: adding a heated seat
Results 1 to 7 of 7
  1. #1 adding a heated seat
    SE Level Member rodneypierce's Avatar
    Jan 2012
    Cedar rapids, IA
    Alright guys, Im looking at a 98 GTP and was wondering....
    Is there a relay or something that also needs to be added when one ad's a heated seat to the car? A good buddy of mine swapped in a heated seat, but it doesnt work. Its a factory heated GP seat. So wonder if there is a relay, or fuse somewhere that needs to also be added?
  2. #2 Re: adding a heated seat
    Omaha, NE
    What all did he install? Just the seat... or...
  3. #3 Re: adding a heated seat
    Jan 2012
    Cedar rapids, IA
    Im not sure. Ill find out more when I go to look at it this week. What all is required? I would assume there is a switch, etc... Sorry, I promise Im not ignorant, nor is he, he is a very solid mechanic/diy guy. Im just not familiar with what all would be needed, or where the switch even goes.
  4. #4 Re: adding a heated seat
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    U can run a switch anywhere u want. Factory puts it in the little coin slot thingy in front of the shifter. U don't have to run a switch, but then u would have to run it to where it gets a constant 12v that is remotely powered.
  5. #5 Re: adding a heated seat
    Take a look at my thread in the how to section on heated seats. There's a how to add and how to fix. You'll want to ensure the switch is sending the module (cool GM talk for relay) the turn on signal and that the relay/module clicks and that it's getting power. Likely you'll find your issue there and won't have to go in to resolder the element.
  6. #6 Re: adding a heated seat
    Jan 2012
    Cedar rapids, IA
    Thanks billboost! I will check it out!
  7. #7 Re: adding a heated seat
    Anytime.. I love telling people to search on my name. It's almost as funny as giving them my Photobucket login.
  1. how to fix a heated seat.
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2019, 06:18 PM
  2. Adding a heated seat
    By PurpleGuy in forum How To Write-Ups/Tech Tips
    Last Post: 02-25-2012, 12:49 PM
  3. my heated seat
    By chevymomma in forum General Grand Prix Discussion
    Last Post: 12-29-2011, 02:02 AM
  4. heated seat
    By Ricky21 in forum General Tech Discussion
    Last Post: 04-23-2010, 10:43 PM
  5. Heated Seat
    By Rather B Blown in forum General Tech Discussion
    Last Post: 12-29-2008, 01:46 AM
