Thread: code but no light
Results 1 to 6 of 6
  1. #1 code but no light
    May 2011
    iowa
    I have been getting a check engine light p0171 i got a pcm from intense thinking it would go away and it stayed off for a little bit but came back on. Well the last couple days the CEL hasnt come on but my aeroforce shows the code keeps coming back any ideas why it would do that?
    1969 chevelle - project car
    2004 Impala SS - Gen V, 3.6 pulley, w-body store headers, SLP power flo catback, 180*, CAI, Northstar throttle body, ported lower intake, intense pcm, egr delete, 104's, zzp strut tower braces, Quad tail light mod, more to come.
  2. #2 Re: code but no light
    Whelp here goes this one...
    What year is your car?
    Intense could have loaded the incorrect year MAF tables into it...since you have a Aeroforce...switch it to the LTFT's (Long Term Fuel Trims)...when idling or coasting off the throttle if your fuel trims peg at +16.4 then you have either...
    A) An actual vacuum leak...which is what the code P0171 is for...
    or..
    B) You have to either have a local retune your car or ship it back to intense and have them flash the correct MAF tables in your PCM (Example: '97-'98 cars have the same MAF tables...but then '99-'03 are different)
  3. #3 Re: code but no light
    Pennsylvania
    Did you screw up your EGR delete on the 2004 Impala? Is the rubber T off the LIM dry rotted?
  4. #4 Re: code but no light
    May 2011
    iowa
    2004 impala ss... Ill check the fuel trims in a bit, they shouldnt have screwed it up i called them and practically beat exactly what i wanted into the guys head. The rubber t is fine and the block off plates are fine. Sorry forgot to mention it started before the egr delete and pcm upgrade. I got the pcm because i thought since i have the headers and etc. i was running lean and needed to get more fuel. Basically I have it narrowed down to a bad/dirty MAF sensor or bad O2 sensor.
  5. #5 Re: code but no light
    The O2 is the sensor reporting the issue, not the cause.
  6. #6 Re: code but no light
    May 2011
    iowa
    yes i know that now i cleaned my maf sensor and filter and code hasn't come back yet so i believe i discovered the problem.
  1. 98 GP GT with a PO442 code and light on.
    By Fritcr in forum General Tech Discussion
    Last Post: 11-17-2011, 06:39 AM
  2. SES light on, Code reader won't power up
    By bobabooie in forum General Tech Discussion
    Last Post: 08-15-2011, 07:13 PM
  3. Sputtering on 98 gtp with no engine light code
    By feonnixxx in forum General Tech Discussion
    Last Post: 04-12-2011, 06:12 PM
  4. CES light on with P0441 code
    By afriendofbillw in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:36 PM
  5. Air Bag Light code:B1015. Any tips?
    By spenc938 in forum General Tech Discussion
    Last Post: 06-27-2008, 05:10 PM
