kcfalcon2000
So I am trying to figure out if my tank is really 17gallons. Filling up the tank from just above empty I usually get around 13gallons in. After filling, the needle moves off of full in less than 20 miles. When it gets low, less than 1/4 of tank the guage fluctuates with accel/decel as well as turns, to a point where it sets of the low level annunciator.
I would suspect the guage....but twice now while decelerating, for a cloverleaf exit, the car stalled and I had to pull over and restart. Mind you being its a GTP ,I try and take the exit at 40-50mph when I should be at 30-40!! I have replaced the fuel pump so is it possible its not seated right???
I just have a hard time believing that with 4-5 gallons that should still be in the tank that it would fluctuate that much.
