Thread: Leaking oil all under car
Results 1 to 8 of 8
  1. #1 Leaking oil all under car
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I can't exactly tell what its from, but i know theres quite a bit of it leaking. Over time though, its not like its just shooting out. Anybody know?
  2. #2 Re: Leaking oil all under car
    Omaha, NE
    Noone will know from that description...
    Start checking gaskets. Get under the car and trace the leak.
  3. #3 Re: Leaking oil all under car
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    check ya oil filter and oil sending unit for starters
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
    The Boss Iceman6669's Avatar
    Jun 2011
    Put it up on ramps/lift and clean all the old oil off the underside. Then let it run for 15 min and see if you can see where the leak is coming from. If it hasn't leaked yet let it run longer. If it has leaked n you still can't find it the wipe it off again and let it run for 5 min and try again
    2011 F-150 Yote powered
  5. #5 Re: Leaking oil all under car
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    The bottom cradle will hold oil, and leak onto the ground when parked at a slight angle. Have a look at the oil pressure sending unit, valve cover gaskets, crank seal...all 3 will cause a decent puddle.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  6. #6 Re: Leaking oil all under car
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Gm cars always have bad valve cover gaskets. So check that. And like stated, oil sending units leak pretty bad. How many miles do u have? Also like stated u need to clean under ur car real REAL good in order to see where its coming from. If u have any connections and can get it on a lift, that would be the best bet
  7. #7 Re: Leaking oil all under car
    new britain, ct
    check your oil lines. i was slowly leaking oil because of a bad clamp. 1.00 fix.
    07 Black GXP.
  8. #8 Re: Leaking oil all under car
    Clean and diagnose.
  1. Leaking Oil!?
    By illtacticz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2011, 10:46 AM
  2. On and off leaking?
    By Fraschy in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-24-2011, 01:11 AM
  3. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  4. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
