After all the work ive had done on this car it still will not start. When it would first not start my mechanic friend said he believed it was the fuel pump. We replaced it with a junk yard pump. This pump appeared to be in great shape and my mechanic friend says he has picked 100s of junk yard fuel pumps. Anyway car started up just fine when we replaced and the car ran for a good 3 hours. Then it died. He came back out checked the pump and said it was still getting good pressure. He did however suggest because the plugs got really fouled and the wires were burned we replace those, replace the upper and lower intake gaskets to get a better seal,and replace the crankshaft position sensor because i did have code for this (would the CPS cause the car not to start?). Anyway all said and done the car still will not start. It will turn like it wants to start,and it did start once real quick and cut back off. My friend now thinks it is still the fuel pump,that the used one is no good. Anyway i dont have much more money to try and repair so i need a cheap,cheap fuel pump but one that will at least function. I came across a site that had some,and the price is really low. I know you get what you pay for but i just need something for the time being ao if you dont mind looking,the site is Fuel Pump Assembly - Fuel Pump Module | Fuel Pump Module Factory Outlet Store
Product: Fuel Pump Assembly Part #: FPKM231 Verify Fitment Notes $123.38
$52.87
$70.51
