Thread: explain something about wheel bearings?
Results 1 to 12 of 12
  1. #1 explain something about wheel bearings?
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    I know this will come as a silly question,but from someone that is learning the very basics about cars its the type of questions you get lol. Anyway ive heard alot about bad wheel bearings,in fact mine might be going bad soon.I know the repair is repacking the bearings.Ok heres my question,is the wheel bearing part of the axle or is it part of the actual wheel that you put the tire on?(when your done laughing and pick yourself off the floor please explain this too me,thanks)
  2. #2 Re: explain something about wheel bearings?
    Donating User Odi's Avatar
    Chicago South Suburbs
    you dont replace the wheel bearings on a w-body. you replace the whole wheel hub, where the bearings are.
  3. #3 Re: explain something about wheel bearings?
    Omaha, NE
    You don't repack these bearings. You buy a whole new assembly.
    The axle/ CV joint slides into the wheel hub assembly.
    The best way to learn is to take things apart at a junkyard. That way when you break it, it doesn't matter.
  4. #4 Re: explain something about wheel bearings?
    Out West
    neither.
    Whine with your Cheese?
  5. #5 Re: explain something about wheel bearings?
    Nov 2011
    portsmouth,virginia
    I just looked up a wheel hub.So its this piece in front of the rotor/brake parts?
  6. #6 Re: explain something about wheel bearings?
    Omaha, NE
    car is that off of?
    Yes the hub assembly is behind the rotor.
  7. #7 Re: explain something about wheel bearings?
    Nov 2011
    portsmouth,virginia
    not mine.i found this one better explains it to me.
  8. #8 Re: explain something about wheel bearings?
    Omaha, NE
    Uhh... Not really.
    Thats a wheel assembly.
  9. #9 Re: explain something about wheel bearings?
    Omaha, NE
    From the inside out its CV > Hub Assembly > Rotor> Wheel.
  10. #10 Re: explain something about wheel bearings?
    Nov 2011
    portsmouth,virginia
    ok thanks.is that an actual GP one? the plug on the side is that for the ABS? So rather than pack bearings i should just replace the whole wheel assembly?
  11. #11 Re: explain something about wheel bearings?
    Omaha, NE
    Yes, that's from a GP and the plug is for ABS.
    You CAN NOT repack these bearings, so you will have to buy a wheel hub assembly. They aren't very expensive, and remember to replace them in pairs.
  12. #12 Re: explain something about wheel bearings?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    you have to replace the whole wheel assembly. yes, the plug is for the abs.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  1. Wheel Hub Bearings??
    By misterman in forum General Tech Discussion
    Last Post: 05-28-2011, 09:06 AM
  2. Wheel Bearings?
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2010, 08:05 PM
  3. Wheel Bearings
    By JAllegar in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2009, 02:57 PM
  4. wheel bearings
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 06-11-2009, 02:45 AM
  5. Wheel Bearings
    By Dangerous313KidInAPrix in forum General Tech Discussion
    Last Post: 02-26-2009, 02:17 AM
