Thread: P0137, P0327 codes question
Results 1 to 15 of 15
  1. #1 P0137, P0327 codes question
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Alright quick question, i know that P0137 is an Oxygen Sensor, and i know that P0327 is a knock sensor. Now i dont know exactly what i need to buy. Do i have to buy one knock sensor and one o2 sensor since theres only two codes? Or do i have to replace them both, and i don't know which one is bad or how to tell.
  2. #2 Re: P0137, P0327 codes question
    GearChatter.com :: View topic - DTC P0137 or P0157
    GearChatter.com :: View topic - DTC P0327 or P0332
    Most of the time the answer is found in the diagnostic aid section.
  3. #3 Re: P0137, P0327 codes question
    Oct 2011
    New Jersey
    Alright thank you
  4. #4 Exhaust sputtering sounds
    Oct 2011
    New Jersey
    Its only when i get the car moving a bit faster, maybe after a faster acceleration. Its only when i get off of the gas, theres a sound coming out the back like if you would make a "fart sound" with your tongue. I also have SES codes P0137 and P0327 if that has anything at all to do with it.
  5. #5 Re: Exhaust sputtering sounds
    Oct 2011
    New Jersey
    Bump
  6. #6 Re: Exhaust sputtering sounds
    what are those codes? I'm to lazy to look them up. Sounds like your backfiring though.
  7. #7 Re: Exhaust sputtering sounds
    Oct 2011
    New Jersey
    O2 sensor and knock sensor. Also, those are your tail lights in my sig pic.
  8. #8 Re: Exhaust sputtering sounds
    Tails look good, what exhaust are you running?
  9. #9 Re: Exhaust sputtering sounds
    Oct 2011
    New Jersey
    The guy i baught it from said its straight piped into two thin bullet mufflers on each side. Its a rather ****ty sound. I ordered the stock mufflers yesterday. I read that it backfires sometimes when an o2 sensor is bad, which is my case.
  10. #10 Re: Exhaust sputtering sounds
    Merged the two threads about the two codes,
  11. #11 Re: P0137, P0327 codes question
    Oct 2011
    New Jersey
    Would this be the right o2 to fix my problem? P0137 is Bank 1 Sensor 2, and my mechanic friend said i need to get a downstream sensor. This seem good to buy?
    http://shop.advanceautoparts.com/web...1_R|GRPEMISAMS_____
  12. #12 Re: P0137, P0327 codes question
    Bosch O2's tend to be hit or miss in our cars. A nice Denso from Rockauto is typically a great price and a good sensor.
  13. #13 Re: P0137, P0327 codes question
    Oct 2011
    New Jersey
    Wow, around $30 on rock auto. This seem correct?
    DENSO Part # 2344087
    More Info
    OE Style
    Wire Length 11.81; O.E. Quality Replacement Sensor; Downstream
  14. #14 Re: P0137, P0327 codes question
    Taht's why I said, great price
  15. #15 Re: P0137, P0327 codes question
    If you have straight pipes then it will make weird noises when you back off the gas because there is nothing to muffle the ****ty sound of a 3800.
  1. Check Engine Light w/code p0327.
    By bhawk in forum General Tech Discussion
    Last Post: 07-19-2011, 05:36 PM
  2. Codes
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2011, 07:02 AM
  3. Car Codes
    By 1996pontiac in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2010, 08:23 AM
  4. Need Help with p0327 and p0332
    By midblue00 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 08:22 AM
  5. GM RPO Codes
    By mkuhn20 in forum General Tech Discussion
    Last Post: 01-21-2009, 04:47 PM
