I was drive my 01 GP and I stepped on it hard and got up to 70 on a hill and the check engine light started flashing but stopped when I got out of the gas.Then later I got up to 100 and it started to flash. Why is it doing that?
Best take that car somewhere and get it scanned. When the dummy light flashes your in limp home mode. Means 'please dont drive me I'm dieing!' and you prob shouldnt until you get the issue taken care of.
It went out after a few seconds.
Thanks
You have a misfire, thats why its flashing.
Pull all the spark plugs and make sure none of them are smashed or broken, then look at your wires and make sure none are broken.
If you dont think the plugs have been changed in a while, maybe you should just replace them all.
Per the FSM the check engine light flashes when a potential catalyst damaging condition is present.
This typically means you have a misfire. This can be a weak coil, bad wire, bad plug or worse.
So would it only be misfiring only when im running it hard? How much is a coil?
Correct, I've had coils go out while running hard. I've also seen plug gap cause issues when running hard etc. So let's diagnose before shotgunning parts.
Read codes and see if you have one cylinder misfire showing up.
Ok thanks!!
I'm running STP injector cleaner when it happend and im still on that tank of gas. would that affect it. I did not have it in when I was going 100 and it happened.
1,3,5 where misfiring so time for a tune up. Thanks for the help
Finally got time to do a tuneup and the back 3 plugs where all different brands and bad lol Its all good now thanks for the help!
